390 block differences?
Old Jun 1, 2006 | 02:37 PM
jk72's Avatar
jk72
What are the differences between the 66 to 68 390s and the 68 to 76 390s
Old Jun 2, 2006 | 11:29 AM
Mike G's Avatar
Mike G
66 and 67 390's were offered in cars, not truck, so they have a higher compression ratio, same with all the car vs. truck compressions. Most of the post 72 motors, found in trucks, are lower compression than cars, as previously stated... And the motors from 71-72 on will have hardened valve seats in the heads for unleaded fuel.
--Mike
Old Jun 2, 2006 | 02:36 PM
BBF250's Avatar
BBF250
Some 66 - 67 390's had bigger intake ports as well.
Old Jun 3, 2006 | 10:42 AM
FFR428's Avatar
FFR428
Needsmorecoffee.
Yep some of the early to mid 66 engines still used the lowriser port heads. The later 66 heads were the new port velocity design we know as the medium riser style. Mike G nailed the other points. Foundrys changed from DIF to MCC in the early 70's. Some blocks had thicker cyl walls but it's a crap shoot unless you knock out a freeze plug and gap the cores. I've seen early castings were a little nicer and somewhat smoother than the later.
G.
