A) Is this well Priced from what I have seen it is
B) Are these all the Gauges I need. The mods I am Planning on having is exhaust, Intake, Lift Pump, and possibly a Chip
C) On the boost reading option should I go with the standard Drill and tap, MAP Line Boost, or AIH Plug With P0541 eliminator.
Thank you for the help I dont know much about gauges but to me truck looks Really cool with them and plus Ive seen all the post about how you need them
I can't find the link to the gauges you are talking about so I cannot comment on the value. I did do the AIH delete prior to my gauge install and then simply drilled/tapped that plug when I got my gauges. I feel that is a good/best spot for a signal on that. Also good practice on the drill/tap of the exhaust for the pyro sender.
OK, I see the link now and that is not a bad deal. I've seen that deal in numerous places. $250 for the gauges and painted pillar as in the aforementioned post is a bargain. I spent the extra for DiPricols from ITP and couldn't be happier with the match and performance. Doesn't mean the others aren't just fine. JMO
buy them from a site sponsor if you can. Garrett @ PDP is a great dude, i talked to him on the phone last night when i was ordering some parts. he's starting that new business and needs all the sales he can to get off on a good start. site sponsor, im almost positive of that.
