Now what?! Loosing prime!!
Old Jun 1, 2006 | 06:23 PM
bigblu78's Avatar
bigblu78
Here for the past few days I have been having trouble with my 88 F-250 acting like it was loosing its prime... In the morning it takes several attempts to get the truck to fire... This afternoon it just wouldn't fire at all... I changed the filter and reprimed the motor and got it to run... When it is running, it runs great.. Not a problem there at all... I checked every line, hose and fitting but I'm still having starting trouble even after changing the filter... What else on this thing could cause this....
Thanks guys....
Old Jun 1, 2006 | 09:26 PM
Dave Sponaugle's Avatar
Dave Sponaugle
Do you still have the filter return line hooked up?
The check valve could be going bad.
Another case where an electric fuel pump would be good.
For what it is worth, Cat is starting to use them on their small machines instead of the mechanical ones. Easier than pumping a primer after you change filters.
No fuel system contamination from filling the filter from another source of fuel.
Old Jun 1, 2006 | 09:50 PM
bigblu78's Avatar
bigblu78
Can I block off my old mechanical pump in the same fashion that you can on say SB Chevy motors and just plumb a electric pump in there instead????
I've been wanting to go to an electric lift pump for convenience but wasn't sure if it was feasable...
BTW... check valve is still good.....
Old Jun 1, 2006 | 10:39 PM
Dave Sponaugle
I think a big block GM plate will bolt right on to close the block up.
Then just install the electric pump, most put it right in front of the tank selector valve.
Protected by the frame and down low so it primes easy from the tanks.
Old Jun 2, 2006 | 10:42 PM
bigblu78's Avatar
bigblu78
Thanks Dave.... I'll try that out....
hubler13f
Jan 25, 2013 11:31 AM
wburge
Oct 17, 2011 05:06 PM
turbojunkie
6.7L Power Stroke Diesel
Aug 1, 2011 07:09 PM
chesshircats2
Nov 8, 2009 12:36 AM
tonygray
Feb 16, 2008 03:16 PM
