shackle flip ouestion
Old Jun 1, 2006 | 03:26 PM
slenherr's Avatar
slenherr
when doing a shackle flip how far does the rear move foward thanks
Old Jun 1, 2006 | 04:12 PM
MBBFord's Avatar
MBBFord
Not enought to create a problem. If you take a before and after pic, it is noticable, but you'd get 3" of lift and clearness out of it and the little the axle is moved doesn't hurt.
Just curious, what all are you doing/plans?
Old Jun 1, 2006 | 05:41 PM
slenherr's Avatar
slenherr
lifting a 77 250 supercab to ride around in and look good and mud every now and then
Old Jun 1, 2006 | 05:45 PM
MBBFord's Avatar
MBBFord
What size tires you wanting to run, b/c if it's a pre 77.5 then you can fit 35s stock w/ out rubbing.
But if you decide to go bigger then go ahead and do the shackle flip(if you'd haul heavy loads alot, then this wouldn't be what you'd want, but for riding around and mudding it's more than enough), and you can get some front add a leafs to level it out alittle. If you still need more room, trim the fenders.
Good luck
Old Jun 2, 2006 | 03:10 PM
slenherr's Avatar
slenherr
it is a 77.5 and am planning on running 38s already lifted the front 10" am getting started on the rear now do you have any idea how much the rear moves foward
Old Jun 2, 2006 | 04:26 PM
seventyseven250's Avatar
seventyseven250
Do you mean how far the rear axle is moved forward or the rear eye of the spring or what?
Old Jun 2, 2006 | 05:30 PM
unrulee's Avatar
unrulee
I've looked into this alot for my 79 250, and I know that if one uses the Sky brackets which lower the rear eye about 9 inches the axle will move forward about 1 1/2 inches. If you don't like the look you can either move your front spring hanger ahead to compensate or you can get zero rate add a leaves that will move yourpring center pins up to an 1 1/2. I'm not totally sold on it due to the decreased load carrying capabilities. For wheeling and not work I'd do it in a heartbeat.
Old Jun 2, 2006 | 08:20 PM
slenherr's Avatar
slenherr
i mean how far the tire will be out of center in fender well
Old Jun 2, 2006 | 08:47 PM
unrulee's Avatar
unrulee
1.5 inches forward, with the Sky brackets. Stock I don't know.
Old Jun 2, 2006 | 09:18 PM
mark a.'s Avatar
mark a.
I didn't like the looks of it, so I dropped my front hangers 3.5" There are pictures in my gallery.
Old Jun 3, 2006 | 02:42 AM
Amtek's Avatar
Amtek
less than half an inch if you are not using any blocks between the leaf springs and the axle. or about an inch to an inch and a half if you are using a 3 inch lift block. a block and a shim amplify the offset when doing a shackle flip.
Old Jun 3, 2006 | 12:48 PM
ivanribic's Avatar
ivanribic
I have comparison pics in my shackle flip gallery.
Old Jun 3, 2006 | 08:46 PM
slenherr's Avatar
slenherr
do you have the sky drop brackets and do you just drop front hanger straight down 3.5 inches none foward or backwards
Old Jun 4, 2006 | 09:54 AM
mark a.'s Avatar
mark a.
They are stock hangers dropped straight down 3.5". I made the back hangers, kind'a coppied the Sky ones. The shackels are home made too with Energy Suspension bushings, and they're stock length. With 6" lift springs & a cupple of thin blocks to level it off got it up to 10".
Old Jun 5, 2006 | 08:27 PM
slenherr's Avatar
slenherr
why not drop front hanger 4.5 inches instead of 3.5 if thats what sky brackets give you in rear
