Thermostat replacement
Old Jun 1, 2006 | 07:47 AM
captbwhite's Avatar
captbwhite
Hello all.
I've long used mysporttrac.com, but am impressed wiot the info I am finding here as well.
Beginning yesterday my temp. gauge needle began hovering around halfway between midway and H (like 1/4 from max). Truck is acting kind of funny, with slight hesitation. When I start the truck up, it's a louder initial "rev" than usual, and after driving when I put it in park, the rpm's rise for a a moment again before settling. Coolant is full at cold, just kind of dirty.
From what I am seeing in posts, it's probably the thermostat, which has never been replaced (now at 146k miles). Everyone says it is easy, and I am pretty good at figuring this stuff out.
But, if anyone could explain/has accessible some basic instructions for replacingthe termostat, it'd be MUCH appreciated.
If you have any other advice, I am all ears.
FYI, I've always had the oil changed every 5k miles. now using the high milage stuff. at 100k, had serpentine belt replaced, ball joints replaced, and all fluid systems serviced (flushed purged etc.).
Thanks. Sorry for the lost post.
Regards,
Brandon
Old Jun 1, 2006 | 02:50 PM
swandog's Avatar
swandog
Brandon,
You didn't mention what year your vehicle is. I just replaced my radiator/hoses and thermostat about two weeks ago. Best advice I can give is to remove the air intake tube and remove the cable to the alternator (after disconnecting the battery of course)...this should give you enough room to get in there with a 10mm socket to pop off the thermostat cover...pay attention to how the original one sits in there...there is some sort of pinhole that needs to be at 12 o'clock. I would replace the hoses as long as your at it....I ordered my parts from directfordparts.com...
hth
Doug
Old Jun 2, 2006 | 05:15 AM
marragtop's Avatar
marragtop
Make sure you get the o-ring gasket. It's not necessarily included with all the T-stats.
Old Jun 2, 2006 | 08:47 AM
stealthone's Avatar
stealthone
at 140k miles, I would consider a couple other items:
flush the coolant circuit
strongly consider replacing both hoses (don't forget bypass hose on waterpump is so equiped) - you don't want to do all this work and blow a hose 100 miles down the road.
install new thermostat
install new coolant
That usually handles it. Remember to recycle your antifreeze (ask at your autoparts store).
Old Jun 4, 2006 | 01:08 AM
aquanaut20's Avatar
aquanaut20
Keep in mind to flush any spilt antifreeze, it is sweet and attracts animals, it is deadly toxic. Pour you old stuff into sealed containers.
Old Jun 6, 2006 | 02:37 PM
captbwhite's Avatar
captbwhite
Thanks for all the replies. I replaced the thermostat that night. Easy fix jsut removing the intake hose. Helps to have the right tools and needle nose pliars to pluck the screws out (and back in). Stant thermostat was expensive ($24 at Pepe Boys) but probably worth it. Couldn't find an O-ring in-stock anywhere, but the original was in good shape. hoses looked to be fine still. Didn't change coolant bc it was already 9pm. That was changed at 100k anyway. All is perfect now. Even got it detailed inside, outside, and under the hood this weekend as a birthday present. Looks like it's only got 50k miles on it! Thanks for the help.
Regards,
Brandon
Old Jun 6, 2006 | 02:39 PM
captbwhite's Avatar
captbwhite
I should proofread more. PEP* BOYS had what I needed.
GoCamping
Nov 12, 2023 06:56 PM
Eric H
Modular V10 (6.8l)
Aug 24, 2011 09:54 PM
knash0727
Apr 10, 2009 12:27 AM
Webslinger
Oct 13, 2003 11:09 PM
DS02F250
Mar 2, 2003 02:09 PM
