Replacing DS3 with DS2 distributor
Old May 31, 2006 | 10:25 AM
zimtok's Avatar
zimtok
1983 F-150 with Variable Venturi set-up with (I think) Duraspark III ignition. (The distributor did not have any vacuum advance.)
With some help from members on this forum I ordered a new distributor and control module (thanks again) and changed it to a Duraspark II with a Holley 2300 carb.
When comparing the new distributor with the old I notice that the shaft below the gear is slightly shorter on the new one.
When it is installed it does engage with the oil pump shaft, but I was wondering if this is going to be a problem in the future? And if so what needs to be done to correct this?
deck60
Large Truck
Oct 21, 2012 08:41 AM
whisler
Dec 11, 2011 07:42 AM
Ford_Six
Jul 18, 2008 10:57 AM
