Charging problems
Old May 31, 2006 | 01:39 AM
pdkloste's Avatar
pdkloste
Charging problems
Need some quick help before I have it towed to the stealership!
Driving around, noticed the battery gauge getting lower. Stayed that way for a couple of days and then went far left and left me stranded today once the batteries were drained. Replaced the alternator, thought that would be the easy fix. Has a noticable draw on the batteries when running. Still stranded and am fixing to have it towed in tommorrow. Have checked connections, maxi fuses etc... I have searched the forums and haven't seen anything that I haven't checked yet. Batteries were good until maybe yesterday.. what am I missing?
I also just replaced the Cam Position Sensor a week ago. Coincidence?
Thanks
Old May 31, 2006 | 05:08 AM
Cuda_jim's Avatar
Cuda_jim
Maybe Glow plug relay is stuck?
Is new alternator working?? I've had new ones that were bad.
I doubt CPS is the problem.
Hope this helps a little. Good luck
JIM
Old May 31, 2006 | 08:06 AM
plowhand's Avatar
plowhand
Playing in the Dirt
Could be a dead cell in one of your batteries, this would drain both batteries. Charge it up, drive to NAPA, Auto zone, Advanced etc. have them check your charging system and load test your batteries. If you cannot drive your truck, take the batteries and alternator out and take them to be checked. This will cost you nothing but time, a dealer will charge. Then you know if it is batteries, alternator or your electrical system. Good Luck.
DeBoerJM
Apr 3, 2013 07:37 PM
Byram
6.2L V8
Aug 20, 2012 07:10 AM
RhondaBruce
1983 - 2012 Ranger & B-Series
Mar 30, 2011 12:33 AM
250FordTruck
Electrical Systems/Wiring
Sep 15, 2009 08:07 PM
Mackey
Apr 4, 2004 09:26 AM
