AC not cold enough
Old May 30, 2006 | 09:23 PM
BlueOvalLover's Avatar
BlueOvalLover
AC not cold enough
93 F250. Converted from R12 to R134a before I bought it. Last summer cooled down just fine. This year not cold enough. Will get as low as 50 degrees at the vent when running down road and RPMs up. But when sitting still, the temperature at the vent goes up to near 80 degrees.
I checked the charge. 55 psi. My next guess is the orifice tube.
What do you think? Any other ideas?
Old May 30, 2006 | 09:30 PM
BlueOvalLover
Forgot one other piece of info..........AC compressor is constantly running. Clutch constantly engaged.
Old May 31, 2006 | 08:42 AM
projectSHO89's Avatar
projectSHO89
Before replacing anything:
1) Check pressures using a manifold guage set. Report readings and ambient temps. Report center vent temp.
2) With engine idling and A/C on, spray the condensor with your garden hose for several minutes while watching your center vent temps. Let us know what happens.
Steve
Old May 31, 2006 | 10:42 AM
hhott71's Avatar
hhott71
can be overcharged.
can have dirty condenser
can have weak clutchfan
Old May 31, 2006 | 12:24 PM
stuart1's Avatar
stuart1
What do you mean the charge is 55?
Old May 31, 2006 | 05:58 PM
BlueOvalLover
OK, had some time to play with the truck this afternoon.
Don't have a full AC manifold gauge set. I've just been using the fill hose & gauge combination to get readings at the low pressure fitting. I understand that this gauge may not be dead on accurate.
Current readings as follows:
At idle, low pressure reads 42 psi, temp at vent approx 70 degrees.
At 1200 rpm, pressure reads 28 psi, temp at vent approx 67 degrees.
Ambient temp in both cases, 85 degrees.
Compressor clutch constantly engaged. No cycling.
With continuous driving, not idling, temp at vent will get down to approx 52 degrees.
Tried running water thru condensor while truck idling. Compressor clutch would begin cycling, and temp at vent went up to about 75 degrees. After taking away water, temp at vent goes back to about 70 degrees, and compressor clutch quits cycling.
I'm stumped. Hope this helps someone figure this out. If not, I'll be buying a gauge set tomorrow. I assume the gauge set is most needed to get the high pressure readings.
Old Jun 6, 2006 | 08:11 PM
xcopterdoc's Avatar
xcopterdoc
Sounds like a blend door problem. Blend door is hanging up and letting outside hot air in. With an idle, lowside pressure reading of 42, the vent temp should be alot cooler.
Old Jun 7, 2006 | 09:00 AM
hhott71's Avatar
hhott71
Agreed, The heater over powers the AC 100:1.
Also the heater is after the AC in the airstream.
so a LITTLE bit of heated air will give you warm AC.
Temporarily clamp the heater hoses. And recheck.
trevorrules
21
Aug 6, 2016 08:28 AM
tp79557
Aug 2, 2016 02:31 PM
46Whizzer
18
Aug 10, 2015 09:19 AM
coachblue502
May 5, 2015 04:53 AM
fastbmw01
2004 - 2008 F150
Sep 2, 2009 07:31 PM
