Help !!!!!
Old May 30, 2006 | 07:59 PM
1972ford_f-100's Avatar
1972ford_f-100
Exclamation Help !!!!!
hey guys i just bought a 84 150 ext. cab long box 300-6 i replaced the dist cap,the wires,rotor,plugs and the thing runs rough as all hell(squze the languige,and the bad spelling lol)but i did the timing and it still runs rough,like its missing,well drving i try to acellerate it seems to be missing but i checked the ohms on everything and its all good,the only thing i havent checked is the icm,but i cant seem to find it...but wut else would cause this.... all my vac lines are good,no leaks. i tightend down the carb....oh i replaced the fuel filter too... all help is greatly apriciated thx
Old May 31, 2006 | 12:14 AM
Bdox's Avatar
Bdox
Double check your firing order!! If all OK, run a compression test.
Old May 31, 2006 | 04:27 AM
srercrcr's Avatar
srercrcr
My truck is exactly like yours.
You should see a link below.
You did well to get the electrical side freshened up....that will pay off for many miles once you find the current problem.
My experience points me to the EGR and the carb itself.
Any history with them?
Old May 31, 2006 | 05:30 AM
Dungeon_Master's Avatar
Dungeon_Master
What did you set the timing at 10º OR 12º BTDC
All spark gaps call for .042-.046
All other carb body numbers except listed below were 10º BTDC fast idle rpm 1600 -carb idle rpm 600-700,* note 550-600 rpm with auto trans in drive*
carb body number 9-77J-R12 is 12º - fast idle rpm 1600 -carb idle rpm 700, 600 rpm for TSP off
carb body number 9-78J-R00 is 12º - fast idle rpm 1600 - carb idle rpm 550
carb body number 9-78J-R11 is 12º - fast idle rpm 1600 - carb idle rpm 550
83 was funky it had 6º,10º 12º BTDC's
85-86 were all 10º BTDC
Old May 31, 2006 | 01:28 PM
1972ford_f-100
i checked the firing order it is corect,i think the egr may be messed up cause i checked it and it didnt pull push nothing so could that be it and the truck has 143,ooo on it with never having a carb rebuild ,so would i be wise to rebuild it
Old May 31, 2006 | 02:27 PM
Piffery1's Avatar
Piffery1
Sounds like EGR Valve is stuck open. If it's the "back pressure type" EGR valve, I don't think it will move without the engine running. I'd take it off and clean it (including the ports/passages it mates with). With that many miles it all probably needs the cleaning even if it's not the main problem. Or you could make a temporary block off out of a piece of heavy gasket material placed between the EGR valve and its port to see if that's the problem.
ZombiePopper
Oct 1, 2014 11:59 AM
AndeyHall
Nov 11, 2010 10:21 PM
mbrparker
Jan 26, 2010 04:49 PM
msmith53
19
Aug 3, 2009 07:03 AM
Heykma
Aerostar
13
Nov 7, 2008 05:53 PM
