Brake Problem Again
Old Sep 7, 1999 | 05:46 PM
Kikker's Avatar
Kikker
Brake Problem Again
Hey Guys,
I thought I had the brake light staying on problem
fixed but it's back again.
I've replaced the master cylinder 3 times now, installed a new brake light switch twice. I've rebled the brakes twice, went through 2 cans of brake fluid.
Has anybody else ever had this problem?
Old Sep 8, 1999 | 05:50 AM
jowilker's Avatar
jowilker
Brake Problem Again
WR, The action is controled by the pedal, check and see if the pedal is fully returned. Pull it all the way back while someone is looking at the lights.
John
Old Sep 8, 1999 | 07:14 AM
StockMan's Avatar
StockMan
Brake Problem Again
John is correct and to the point as usual. On the 65/66 "single resevoir" Master Cylinder (MC), the brake lights are controlled by a pressure switch mounted on the MC. If your pedal is not returning to zero because of a problem with the pedal assy, or due to the push rod being too long, the result will be residual pressure trapped in the system which will trigger the false brake light condition and make them come on when they shouldn't. Since it hasn't been determined whether you have the correct MC or pushrod, you really should measure the length of the rod (center of hole to push end) and post it. Also measure the size of the master-cylinder bore and depth of the push-rod hole. You need to eliminate sources of trouble. Otherwise, you may never hit on the solution.
Stock Man
1967 Galaxie 500 Convertible (HELP!---I need 15 x5 factory rims)
1967 F-250 FE 390 4wd
1966 F-250 I6 240 2wd LWB Flare Side
<a href="http://www.hometown.aol.com/tbeeee">http://www.hometown.aol.com/tbeeee</a>
Old Sep 8, 1999 | 07:17 AM
StockMan's Avatar
StockMan
Brake Problem Again
BEFORE YOU DO ANYTHING.....test to see if the lights are still on, then simply remove the push rod. Observe the lights. If off you have now isolated the cause. If on more investigation needed.
Stock Man
Old Feb 13, 2002 | 08:43 AM
jas88's Avatar
jas88
Brake Problem Again
Do you mean your brake lights, i.e., the ones on the rear of the bed, are staying on, or is the Brake System warning light that is on the lower left hand side of the dash?
Old Feb 13, 2002 | 11:06 AM
Mil1ion's Avatar
Mil1ion
Brake Problem Again
This thread is 5 months old.
IIRC
I'm pretty sure he had the problem fixed back in Sept or Oct.
Dennis
Please Don't Ask Me Any Tough Questions As:
"I'm Saving My Memory For When I Develop Alzheimer's"
78 F-150 429CJ,Silver
w/Explorer Pkge.
641/2-Mustang 260,Pre-World's Fair Car.
64-Fairlane500 S/C waiting for a 390-4spd.
68-Mustang 289-Sunlit Gold 80,892Mi
78-Buick LeSabre 403 4V
84 Volvo DL Wagon
Old Feb 13, 2002 | 12:00 PM
jowilker's Avatar
jowilker
Brake Problem Again
Dennis look again. :-)
http://www.clubfte.com/users/jowilker/USFlag.gif
John
jowilker email me
[link:www.ford-trucks.com/users/jowilker|My Club FTE Page] Member since 01 01
[link:www.ford-trucks.net/users/jowilker/NCFTE.html|NCFTO] North Carolina Ford Truck Owners Group
In the cool still quiet of night, you can hear chevies rusting away.
Old Feb 13, 2002 | 12:34 PM
Mil1ion's Avatar
Mil1ion
Brake Problem Again
DUH ME !
Who says I need glasses to make a spectacle of myself?
Re-phrase ,
His post is 29 months old.
*Note: September 1999
Dennis
w/Explorer Pkge.
84 Volvo DL Wagon
Old Feb 13, 2002 | 01:57 PM
jas88's Avatar
jas88
Brake Problem Again
How did it get back to the top without a post? I only look at the first page when I come to the message boards.
Old Feb 13, 2002 | 02:19 PM
Mil1ion's Avatar
Mil1ion
Brake Problem Again
When you REPLIED it automatically brought it to the top of the order.
The message boards show every post chronologically.
Dennis
w/Explorer Pkge.
84 Volvo DL Wagon
Old Feb 14, 2002 | 09:01 AM
jas88's Avatar
jas88
Brake Problem Again
But it was at the top BEFORE I replied. I only look at the first page of threads. A 2 year old post is not going to be on the first page.
Old Feb 14, 2002 | 09:07 AM
jas88's Avatar
jas88
Brake Problem Again
Oh, this answered my question:
https://www.ford-trucks.com/dcforum/DCForumID73/1312.html
Old Feb 14, 2002 | 01:12 PM
Mil1ion's Avatar
Mil1ion
Brake Problem Again
OldWoodsDiesel
Jan 7, 2013 08:00 AM
Pool Runner
2009 - 2014 F150
Jul 28, 2012 03:51 PM
TGenolcyC66
2004 - 2008 F150
Jun 27, 2011 06:20 PM
thordehr
Dec 30, 2010 12:36 PM
