gauges
Old May 30, 2006 | 06:59 PM
DPO152's Avatar
DPO152
gauges
I am going to put a boost gauge, tranny temp, and a egt gauge in. Should I go pre turbo or post. Its a 2001 7.3.
Thankx
Old May 30, 2006 | 07:11 PM
maevans's Avatar
maevans
IMO -- I would go pre turbo. If you do a search, you can do a lot of reading about PRE or POST turbo, that may give you more insight, Hope it helps.
Old May 30, 2006 | 07:27 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
pre turbo defanitely. it is more accurate, you need to monitor temps coming from the engine, not the turbo. the pre turbo location is much more accurate. do some searching.
Old May 30, 2006 | 08:06 PM
jtharvey's Avatar
jtharvey
Pre Turbo is the only way to go. I've done some testing on it. Read here:
https://www.ford-trucks.com/forums/s....php?p=3684558
radamx2
Apr 11, 2012 08:21 PM
fordguy712
Nov 5, 2008 07:49 AM
cdiddy
Jan 4, 2008 11:38 PM
mattri
Aug 21, 2007 02:25 PM
