Burning/Break-in smell
Old May 30, 2006 | 06:05 PM
SHWILL's Avatar
SHWILL
I have a 2006 6.0 crew cab 4x4 with 3,700 miles. When I get out of the truck I often smell a buring/brake smell when exiting. You can not smell it in the cab. Is this normal? It doesn't matter if I brake hard or not when stopping. The smell is the same. I do not always notice the smell. I love this truck.
Old May 30, 2006 | 06:13 PM
bigredtruckmi's Avatar
bigredtruckmi
Veteran: Navy
With this many miles everything should be seated in. Could be a brake is not completely releasing. I would take it in and let them tear into it to be safe.
Please update your signature. It shows a chevy.....
Old May 30, 2006 | 10:39 PM
Jawbreaker's Avatar
Jawbreaker
Smells like burning tires???? My 06 350 with 1000 miles has the burning rubber smell at idle when hot since I brought it home three weeks ago. Dealer says it will burn off, getting less and less as the miles go by. Still have to turn on the recir.... when I lift the hood, smells like it is coming from the radiator hose....but 3500 is a lot for new burn off smell.
Old May 31, 2006 | 04:36 AM
04SD6.0's Avatar
04SD6.0
I have a 2004 CC Lariat with 31,000 miles and after I drive it for 20-30 miles, or longer I can still smell that same break-in smell, nothing to worry about, just a sweet truck warming up!!!!
Old May 31, 2006 | 06:07 AM
texcan's Avatar
texcan
Could be a brake hanging. Have them check the slide pins the might be frozen.
Old Jun 1, 2006 | 06:14 PM
SHWILL's Avatar
SHWILL
Will do. Thanks Guys
Stu206
Jan 10, 2014 05:00 PM
babgrip
Mar 30, 2009 06:43 AM
Les-b
Jan 31, 2009 09:57 AM
fordxl68
2004 - 2008 F150
Apr 5, 2008 10:32 PM
Chris McGovern
Oct 21, 1999 01:12 AM
