Heater core valve?
Old Jun 18, 2006 | 10:03 PM
fmr9's Avatar
fmr9
Thanks for the additional info.
I have been thinking about this. I like to run my heater thru the vents in really cold weather. Because of this, I think I will go with a manual control for the valve. Should just have to switch it twice a year. Close it early summer and open it early fall.
Old Jun 18, 2006 | 11:16 PM
OneFifty96's Avatar
OneFifty96
I've seen people saying it before, why not just run the hose (or a shorter hose) back into the block? its simple and solves your problem. As for the problem of teh heater core possible rusting through from the stagnant coolent, just blast an air compressor into the idle hose and clean it out. Should work fine, since I did it when my heater core was leaking.
Old Nov 17, 2006 | 01:33 AM
F350JOHN's Avatar
F350JOHN
Sorry to steer the topic off course slightly, but my 1992 F-350 with the heater on hot and high, just blows luke warm air out. I changed the thermostat, but to my suprise, it fixed nothing.
Any help in the right direction would be awesome.
Thanks,
John
Old Nov 17, 2006 | 07:06 AM
fmr9's Avatar
fmr9
John, there are two likely causes of what you described. Either the blend door is not working right, or the heater core is mostly plugged with crud. You need to verify the blend door is opening and closing properly. If it is stuck, you add enough outside air to keep the heater from doing it's job. Sometimes this is a vacum problem, or something can fall down thru the defrost vents and jam the vent door. Pen, pencil, kids toys are some possibilitys.
If the door is opening and closing fully, then check the heater hoses. Both should be
Hot. This only indicates that at least some water is circulating thru the core. Doesn't indicate how much water. If partially plugged and hoses will still both be hot. You can try pulling both hoses off the engine and using a garden hose to back flush the core. That might help. The core is pretty easy to replace, and not too expensive, about $30. If it were my truck, and I suspected a partially plugged core, I would just replace it.
Good luck Frank
Old Mar 28, 2007 | 06:40 AM
350z's Avatar
350z
Arrow
Did anyone find the part number for the vacuum operated valve ? One of the board sponsers has them , Craig.
Old Mar 28, 2007 | 07:27 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
D4AZ-18495-A Vacuum Controlled Inline Heater Valve (Motorcraft YG-136)
C3UZ-18495-A Inline Heater Valve, Cable Operated (Motorcraft YG-133)
D1HZ-18495-B .. Manual Heater Control Valve (Motorcraft YG-126)-this valve resembles a outside water faucet and works on the same principle. It has a 90 degree 5/8" nipple to attach the heater hose. It screws into the manifold.
Old Mar 28, 2007 | 03:24 PM
F350JOHN's Avatar
F350JOHN
Smile
Hey Frank,
Thanks to all you guys, I replaced my heater core, and the problem went away totally. I wished I had access to a remote mount filter head at the same time I replaced my heater core, I would like to run a coolant filter to catch all the crud floating around. (Before I plug up my new heater core!)
Because I'm too cheap to do a coolant flush! LOL
Old Mar 29, 2007 | 12:24 AM
fmr9's Avatar
fmr9
Glad things worked out for you. Your thriftyness with the coolant reminded me of my Grandpa. Back in the early 50's, watched him drain out the coolant in the spring and store it till next winter. He put it in a couple of glass 1 gallon milk jugs with aluminum foil lids, and set it in the basement. Lots of crude went to the bottom, and he strained it thru cheese cloth as he very carefully poured it back in the radiator.
Frank
Skiddy 1
Jun 30, 2017 03:56 PM
Rangersmith1
Escape & Escape Hybrid
Jul 28, 2015 08:49 AM
Ranger Bob
2004 - 2008 F150
Jan 14, 2014 12:48 PM
moxy123
13
Dec 18, 2007 02:12 AM
Mr. Farknocker
1983 - 2012 Ranger & B-Series
Feb 7, 2005 06:22 AM
