vacuum check valves
Old Dec 16, 2013 | 12:49 PM
Ranger Bob's Avatar
Ranger Bob
vacuum check valves
I have some bad vacuum check valves in my IWE system and I'm having trouble finding new check valves. Ford will sell them but not separately. I'd have to buy the hole section of line for $18 to replace 1 check valve. Then $22 for the second bad valve. About $60 to replace all three.
Does anyone know a good source for these.
Old Dec 16, 2013 | 03:32 PM
60DRB's Avatar
60DRB
Advance usually has check valves for $4-$6 each. The vacuum line as well, by the foot.
Old Jan 7, 2014 | 10:41 PM
eshallbetter's Avatar
eshallbetter
You probably have your answer already, but I'll post up in case it will help someone else. I had read in another forum this is what you need for the IWE vacuum lines.
Amazon.com: MOTORCRAFT YG-360
I just ordered one but it won't be here until this weekend. I'll try and post back to confirm if it is the correct part. As you mention, I could only find the lines, and figured for 10 bucks I would take my chances.
Old Jan 13, 2014 | 06:40 PM
eshallbetter
OK, the vacuum check valve I posted a part number for above is the check valve inline to the motor. However, although the "black" side is for a larger hose, it does fit in line at the solenoid. I have not been able to find the "correct" valve for the solenoid side, but seem to be successfully using the larger valve for now. I will update if/when I experience catastrophic failure!
Old Jan 14, 2014 | 12:48 PM
EBC-150's Avatar
EBC-150
Yeah, I had to use the 1/4" to 1/8" check at the solenoid. According to my dealer, the 1/8" to 1/8" check valve part number has been replaced with the YG-360. Also, I have not been able to find the check valve closest to the brake booster without purchasing it with the hose. It is 1/4" in and out. My dealer wants $38!!! However, I was able to successfully clean this one with electrical cleaner and WD-40. It works fine now. I believe that's because it was the furthest away from the debris/rust being sucked through the system.
theduke308
2004 - 2008 F150
Jul 21, 2012 07:47 PM
ladiabla74
1997 - 2003 F150
Jul 30, 2008 09:03 PM
ckrichard
Jun 11, 2007 12:36 AM
rbastedo
Aerostar
Sep 9, 2002 07:51 PM
teeruck
1983 - 2012 Ranger & B-Series
Nov 29, 2001 01:20 PM
