My 67 F100 doesn't sit level (tilts about an inch lower on driver's side rear). Is this usually due to shot springs? Is it a big job to replace the leaves in the back?
Also, I want a couple more inches lift. I can quickly understand how a lift kit in the rear will work (a couple more leaves) but in the front I have no idea how a lift kit would accomplish it's goal. Longer coil springs, or some kind of block that sits under/over the springs?
The rear leaf springs aren't so bad to replace. Everything might be a little tight or rusty to get off, but it's not a bad job. You can always cut the u-bolts, they have to be replaced anyway whenever you work with them. I wouldn't go with add-a leafs if the truck is already hanging to one side...liable to be sitting higher, but still hanging when you are done. It's also possible that one side had been replaced sometime in the past 35 years, and one is stronger than the other. I'd replace both of them.
The front coils is the same deal. Replacing the coils with longer ones, or even new stock ones will bring that front end back up! Of course if you go with longer coils make sure you get longer shocks as well...
re: saggin sixty sevens. springs alone may not help.
My 67 had/has same problem, I changed front springs, new 2" lower springs, had rear pack reconditioned, I leaf removed both sides and de-arched to lower. And it still sits slightly lower drivers side.
Truck is being blown apart for full restorod make over, and I'm told that new body/bed mount kits should take care of problem.I'll know in near future. I also had an aux tank on drivers side which may have contributed to uneven weight distribution over years. Trevor-CACWBY in WI
I solved the worn out rear spring problem on my '72 with F250 springs. If you put longer front coils on you're going to have to find a place that is capable of bending the front I-Beams. This is the only way to get the camber adjusted on these trucks.
>these trucks.
Any decent truck alignment shop should have
the equipment to do that, hell, I've got 3 or 4
in my neighborhood...
