Backfiring
Old Oct 23, 2001 | 01:25 PM
karljay's Avatar
karljay
Backfiring
Old Feb 14, 2002 | 09:08 PM
thewall's Avatar
thewall
Backfiring
Is there any other reason besides timing that would cause my truck to backfire? It's a 390/c6 combo in a '72 Camper special. Once the truck is warm, if I put my foot into it to go up a hill or accelerate past someone, it gives a couple violent backfires before deciding to get moving. I have the timing set at the timing mark that it was set on when I purchased the truck a couple months ago. I believe it is at 6 degrees btdc. Any help would be appreciated, I don't know if it matters but the temperature here has been just above the freezing mark but I let the truck run with the manual choke for 10-15 minutes before attempting to go anywhere. I only use it to go to and from work mainly which is only 4-5 miles each way. I do take it out for a good run on the freeway once a week or so just to clean things out.
Thanks in advance,
Don W.
Old Feb 14, 2002 | 11:12 PM
Mil1ion's Avatar
Mil1ion
Backfiring
Crossfiring inside the distributor cap caused by:
Cracked Cap,Worn distributor shaft.
Dennis https://www.ford-trucks.com/user_gallery/sizeimage.php?&photoid=1733&.jpg
Please Don't Ask Me Any Tough Questions As:
"I'm Saving My Memory For When I Develop Alzheimer's"
78 F-150 429CJ,Silver
w/Explorer Pkge.
641/2-Mustang 260,Pre-World's Fair Car.
64-Fairlane500 S/C waiting for a 390-4spd.
68-Mustang 289-Sunlit Gold 80,892Mi
78-Buick LeSabre 403 4V
84 Volvo DL Wagon
Old Feb 15, 2002 | 12:07 PM
thewall's Avatar
thewall
Backfiring
Thanks Dennis, it's a relatively new cap, how do I check for
a worn distributor shaft? Will it just have play in it?
Don
Old Feb 15, 2002 | 12:30 PM
Mil1ion's Avatar
Mil1ion
Backfiring
Yep !
I forgot to mention that Moisture in the Cap can play part of BF too.
w/Explorer Pkge.
84 Volvo DL Wagon
Old Feb 16, 2002 | 07:38 AM
oleblue70's Avatar
oleblue70
Backfiring
Hopefully your problem lies in the ignition.But,Sounds to me like exhaust valve float.I had a truck that did that under load and it had alot of mils on it.I put new springs in it and it quit.Another case:I have a truck that i leave sit for long periods,when i first start it it backfires and pops,then will quit after 1/2 hour of running.That is a valve hanging up or i call a lazy spring,or carbon stuck on the seat.
