F250 PSD Starter problem
Old May 30, 2006 | 09:24 AM
Ryan Waller's Avatar
Ryan Waller
I've seen a lot of postings on this issue and I'm sure this has been covered, but I'm broke down and need help. Starter has been grinding for some time, but the truck would eventually crank. It finally quit. The truck will turn over for a second or two, make a grinding noise, and then just spins. Will not start. Does this sound like a starter issue?
Old May 30, 2006 | 10:31 AM
Rancha9's Avatar
Rancha9
Yes... As long as the starter relay is still good (which it sounds lke it is...). New starters are readily available, cheap, and pretty easy to install too... Just disconnect BOTH batteries first, and don't let it drop on your sternum... (Please don't ask how I know this... )
Old May 30, 2006 | 11:28 AM
psdpower's Avatar
psdpower
They are real easy to change, just three bolts (17mm I think). I had good luck with the Bosch reman I put on my 99. A stubby 17mm wrench really helps on the top bolt.
nothercrash
16
Jul 1, 2015 10:45 PM
90pioneer
Jan 12, 2014 02:51 PM
96F150HuntingTruck
Apr 21, 2011 10:37 PM
budhead1
Jan 27, 2006 04:10 PM
bremen242
Aug 24, 2004 03:41 PM
