guttless(and I hate it)
Old May 29, 2006 | 09:00 PM
factory594x4's Avatar
factory594x4
Angry guttless(and I hate it)
I have a 91' ranger 2.3l 4speed w/ overdrive. This sounds weird but it idles rough, it's guttless and slow, but it runs fine. Any help with the guttlessness and slowness????
Old May 29, 2006 | 09:13 PM
JD717's Avatar
JD717
umm, swap for a 5.0? lol just kidding. you could probably change all the filters, run some fuel injector cleaner through it, and see what happens.
Old May 29, 2006 | 10:09 PM
factory594x4
I’ve done most of that type stuff. I changed the timing belt,thermo and water pump at 140k. It’s at 150k now
Old May 30, 2006 | 03:29 AM
CowboyBilly9Mile's Avatar
CowboyBilly9Mile
Assuming that it's in good tune and a compression test produces average results, I'd say you will simply have to accept the power offered by the motor you've got. Then again, with some work a BB can be stuffed in there too .
Old May 30, 2006 | 10:53 AM
RangerPilot's Avatar
RangerPilot
When you did the timing belt did you get the timing back on where it's supposed to be?
RP
Zach
Old May 30, 2006 | 11:02 AM
ColonyPark's Avatar
ColonyPark
Did it run any differently before and after the timing belt change? The 2.3 isn't potent, but it's sufficient for daily driving. It sounds like you might be a tooth off on timing.
Old May 30, 2006 | 11:23 AM
factory594x4
It runs the same as before. I did the t/belt because of my problems. The timing is dead on. I think it is just a suckass lame engine, I was right I HATE that thing.
What about the rough idle?
Does anyone know how much a regular cab 2wd ranger weighs?
Did they make a dual overhead cam version?
What is the rear end ratio?
Thanks
Old May 30, 2006 | 11:44 AM
ColonyPark's Avatar
ColonyPark
Thanks
First, look at the door placard. It'll have the axle code on it. You can look it up here on this site.
Second,if you hate it so bad, you need to ask yourself why. Why don't you replace it with something you like? Why did you buy it to begin with? Or, as I suspect, if it was given to you by your parents, why are you so ungrateful and spoiled? ;-)
Old May 30, 2006 | 07:34 PM
factory594x4
I have a 78'f-250 4x4 400c6 sucks to much gas. I have a 79' f-250 4x2 460c6 sucks even more gas. I have a 59'f-250 4x4 223 4speed it's great, but with 4:56 gears it's hard to reach 45mph. I bought the ranger to get to the job site and carry my tools economically. I also have a 63' fairlane, but I'm in the middle of doing the interior, so no driving that for now.
Old May 30, 2006 | 09:33 PM
ColonyPark's Avatar
ColonyPark
It's hard to tell from what you've said so far if there's something wrong with the truck, or if you just don't like the power it has.
I'll agree that the little 2.3 is hard to step down to if you're coming to it from power. In 1996 I almost traded my 92 4.0 for a new 2.3, but I just couldn't handle the step down in power then. Now that I don't have to drive like a bat out of hell all the time, I've found that the 2.3 ain't so bad, especially at the pump. It does take some getting used to though.
Part of the problem is that yours is coupled to an automatic. That sucks a lot of the power out of it too.
I guess it's just a matter of compromise. You can't get good gas mileage with a big engine, and you can't get big power from a small engine.
I have to ask tho, didn't you test drive this vehicle?
Old May 30, 2006 | 11:31 PM
factory594x4
Yes I did test drive it. It was in Az. on flat land. It had never had a tune-up, so I figured new plugs, wires and so on would do the trick. I live in L.A, not too many hills but any mountain or hill that I do meet and thats it. I'm sorry it is the manual 4speed w/OD
Old May 31, 2006 | 01:29 AM
bigjohn1985's Avatar
bigjohn1985
i had a ranger with a 2.3 that was a rocket but i took all the wate off i could (took it from 4300 lb to 3900 lb) an i had 15'' rims with lopro tires
oh and if your 2.3 is running ruff check the fuel pump
or your vacume if its loosing vacume it will run ruff and have no *****
and make sure that a rat didnt make a home in 1 of your intake tubes
Old May 31, 2006 | 01:01 PM
MattyF's Avatar
MattyF
what about the cat. converter? My jeep was having serious power problems, and it turned out the cat was almost completely plugged up.
Old May 31, 2006 | 02:11 PM
RangerPilot
And don't be afraid to rev the little four banger, it will really run but you gotta give it some gas.
RP
Zach
Old May 31, 2006 | 09:25 PM
factory594x4
I'm kind of scared to rev it up. I don't think it likes it very much, it sure doesn't sound like it does.
