Bleeding a clutch
Old May 29, 2006 | 03:25 PM
papadelogan's Avatar
papadelogan
Snowboard season cometh..
Unhappy Bleeding a clutch
First off: I have an '88 F350 Diesel, and it's my first truck ever. The previous owner told me there was an allen head bolt used to bleed the clutch, but i can't find it. No, he's not full of crap because the 1st time I went to pick it up, the master cylinder failed completely. We replaced that, and when we went to bleed it, the only tool he took under the truck was an allen key. So my question is...
WHERE IS THIS DARN BLEED SCREW???
I *think* I have an external slave cylinder, and I can't find the *normal* bleed screw on it anywhere - *normal* meaning like what I'm used to seeing on brake systems.
Any help is greatly appreciated!! THANKS!!!
Old May 29, 2006 | 03:59 PM
b2_tim's Avatar
b2_tim
Limited experience
I have a Bronco II but I would trace the hydraulic line down, it should be near it. Mine was protruding from the slave cylinder at the bell housing, like a bolt head. I used a box wrench and my lovely wife on the pedal, to bleed it. Good luck.
Old May 29, 2006 | 04:29 PM
papadelogan
Found it...
I should get in the habit of eating before working on my truck... that way my brain works properly!!!
It uses a 4mm allen wrench, and is on the top side of the slave cylinder, just behind where the hydraulic line connects.
