Need Help W/ Ls Axle ?
Old May 3, 2006 | 10:33 AM
94E150's Avatar
94E150
I Have A '94 E150 5.8,e4od,3.55 Reg. Axle,4w Abs, Van.
Want To Put In A 3.73 Limitted Slip Axle.
Can Anyone Help W/ What To Look For,year,model And
Any Other Thoughts.
Thanks In Advance, Carson
Old May 7, 2006 | 02:55 PM
94E150's Avatar
94E150
[b]i Have Not Been Able To Find Any Good Information On My Post!
Help Anyone ?
Thanks Carson
Old May 8, 2006 | 12:16 PM
andym's Avatar
andym
Why do you want to do this? Going from 3.55 to 3.73 is barely going to be noticable at all. If you just want the LS, then there are lots of options - but it depends on what you're going to use the van for.
Old May 8, 2006 | 07:54 PM
aurgathor's Avatar
aurgathor
Finding an 8.8" axle with 3.73 gears may be a bit (?!) difficult. I think the OEM ratios were 3.55, 4.11, and a couple of highway ratios, but nothing between the 3.55 and 4.11.
So your only realistic option is to redo your axle. Make it LS and change the gears. But it won't be cheap, especially if you have to pay someone.
Old May 8, 2006 | 08:58 PM
MustangGT221's Avatar
MustangGT221
There were no 3.73s...or 4.10s (lightning only). The most popular ratios are 3.08 and 3.55....with 2.73 and 3.31 as rare options.
You'd have to buy 3.73s and put them in if that is what you want.
Old May 8, 2006 | 10:36 PM
94E150's Avatar
94E150
Thanks for all of your posts.
I plan on using the van for surf trips to Baja,and some of it
will be off road,sand and such.So I want to put some
BFGoogrich T/A KO tires on,taller and wider.I was afrad
that the ratio would get out of wack
When I looked at the '94 van owner guide that came with
it,it shows that thir is a dana 3.73 L/S ,I looked just now
and it must be a E250 becase it is a 5,400 lb.
If money was not a problem I would buy a new Sportsmoble
4x4 but such is not the case,so does anybody have any
ideas. I drive van every day for work.
Thanks Carson
Old May 9, 2006 | 12:20 PM
pronstar's Avatar
pronstar
4.10s are only 15% more gear than your 3.55. Add 15% to your current RPM at a given speeed, and that will give you what your RPM will be with 4.10s.
If you get taller tires, the difference will be less, and you'll need the additional torque multiplication to maintain good acceleration at any rate.
I don't know what your internal tranny ratios are, but I'm guessing they aren't far off from my 97 Expy's E4OD. I run 4.10s with street-sized tires and I think it's perfect. These are very heavy vehicles and you need all the advantage you can get.
Old May 9, 2006 | 12:38 PM
MustangGT221
There is an actual formula to calculate RPM in respect to gear ratio and tire size.
MPH x GEAR RATIO x 336 / TIRE SIZE * OVERDRIVE GEAR RATIO
That forumula would give you the RPM in overdrive.
Old May 29, 2006 | 10:32 AM
94E150's Avatar
94E150
Thanks for the good advice.
I would like to try and find a diff to swap before redoing mine if I can.
After reading your posts I can see that a LS 4.10 or 4.11 w/ 31" tires is the only way to go.
If anyone can help me find out what Diff. will fit under my van would be great and if it had disc breaks it would be even better. CARSON
Old May 29, 2006 | 12:40 PM
chrono4's Avatar
chrono4
my 88 had a 8.8 with 3.73 ls in it stock. im almost positive on that one, but now its dana 60 44 with 4.10's.
Old May 29, 2006 | 06:51 PM
aurgathor's Avatar
aurgathor
What does the door sticker says under axle code?
Old May 29, 2006 | 06:52 PM
chrono4's Avatar
chrono4
ill have to look next time im at the shop.
Old May 29, 2006 | 10:12 PM
RTM's Avatar
RTM
The explorer rear axles are very common with 3L73 gears and even 4L10 gears. I have an 8.8 rear disk brake axle that has 3L73 gears in it. So they can be had and I am not sure what year ford started but some where along the line the explorers started getting 31 spline axles.
I know this may not be a good comparrison but i noticed a change in ratios in my 65 mustang when I went from 3L50 to 3L70. It was enough change that for a street driven car i would not go to 4.10 gears. The car is lighter than a truck so the truck may not feel the same as a light car would.
Old May 29, 2006 | 11:02 PM
aurgathor's Avatar
aurgathor
That's correct. And Rangers can have that, too, but this is the first time I've heard of a stok 3.73 in a Bronco. Not impossible, but I find it highly unlikely.
