Garage & Workshop Tips & Ideas for the garage or workshop. No Truck Tech Discussion
using a torch to remove a stuck bolt
Old Jun 11, 2006 | 09:22 AM
Bart99GT's Avatar
Bart99GT
Originally Posted by fellro86
Aluminum won't show red, it will just melt... you shouldn't need a cutting torch or such to heat it enough, a regular propane torch likely would work.
I second that, don't use anything but propane to heat aluminium. Even then it should only take a few seconds of heat to make it expand enough to break the plug loose. I used a little heat when replacing the races in the T5 in my Mustang and it only took about 5-6 seconds worth of heat from a propane torch for the race to seat with a little added persuation from a rubber mallet. The job would have normally called for using a press to install the new race.
Old Jun 16, 2006 | 04:11 PM
helpfulguy's Avatar
helpfulguy
I would not expect it to work on a filler bolt in an trany, I had the same problem on my truck, I tried heat, penitrating oil, cheater pipe, i finally broke the plug head and then drilled and retapped. best i could figure is either someone cross threaded it or used an impact on it. It should not get corrosion on steel threads in an aluminum housing filled with oil.
931jeremy17
Offroad & 4x4
Mar 9, 2014 07:33 AM
Nitramjr
32
May 1, 2009 05:38 PM
jkorreck
Garage & Workshop
Jul 11, 2004 05:56 PM
Wrecker
Exhaust Systems
Jan 31, 2003 08:22 PM
