power steering swap
Old May 28, 2006 | 11:28 PM
1966 f-100's Avatar
1966 f-100
power steering swap
hello every one,i going to change my 66 merc 1/2 ton from manual to power steering . i have a box out of a 73 to79 truck, with a floor shifter will the steering cloumn out of a 66 with a 4 speed work with out shorting it?
Old May 29, 2006 | 04:26 AM
jowilker's Avatar
jowilker
In short, NO.The new gear is longer on top where the shaft connects to and requires the shorter one from the same donor truck.
John
Old May 29, 2006 | 05:41 AM
daveengelson's Avatar
daveengelson
Should not need to shorten the column just the shaft. Not sure, taking the shorter shaft out of a late model column may work. Note, in my case, found aligning the column to the steering box brougth the column slightly lower where the column and boot mount at the firewall requiring slight modification.
dave
Old May 29, 2006 | 06:22 AM
jowilker's Avatar
jowilker
Hi Dave, I think as a group of responders, we want to keep our answers simple. While you are quite correct, a poster might not know a whatcahmycallit from a thingamagig, like you do and could become more confused.
The forum would be better served recommending installing the donor column along with the gear. IMHO
John
Old May 29, 2006 | 03:58 PM
jav409's Avatar
jav409
Thats what I did, pulled the box,pump, cooler, lines, and colum out of a 79, found a pump mount out of a 72 the 79 had a 460. I chose the auto colum cause I was thinking of converting to a automatic, sence then I have, every thing bolted up, had to modifi the wireing and used two long stainless bolts to
hold the colum up. has worked ever sence. As an added benny I was able to go to a 13" wheel and this left lots of room for me and that steak dinner with all you can eat shrimp, if ya know what I mean.
Old May 29, 2006 | 05:07 PM
daveengelson
Came across a 66 column w/ auto shift from salvage yard someone had already shortened. Did not need the 66 column so took the shortened shaft and stuck it in my original 65 column, with the 4 speed. Did not have to deal with modifying the mount at the dash or wire harness. Intend to upgrade my other 65, and already obtained the column from 76, will be swapping the mounting brackets. Unless, decide going w/ automatic and putting the shortened 66 column to good use.
dave
Old May 29, 2006 | 06:46 PM
"Beemer Nut"'s Avatar
"Beemer Nut"
You can change a manual box system to a Ford PS box, also need column, firewall mount plate, left motor perch and pitman arm then bolt it in. If you use a Bendix PS box that will bolt in as it is the same length as the manual box. To locate a Bendix PS box well rebuilders want $250 core charge alone. Bendix box made for 67 to early 69 Ford trucks only, not used on other Fords. The Bendix box your looking for is a hard to find item, they tend to leak at the steering input seal and the seal kit is not available thru Ford anymore. This is why I changed out my Bendix box, column, pitman arm and firewall mount.
The Bendix is more sensitive than a Ford box at speed, another reason why I switched to a Ford box, made another dust collector on the wall with the Bendix box.
.....=o&o>.....
Old May 29, 2006 | 09:37 PM
1966 f-100's Avatar
1966 f-100
thanks for the info!
Old May 31, 2006 | 11:15 PM
cdherman's Avatar
cdherman
I think this may be blocked by the powers that be, but the best place to get better information on this swap is over at www.ford ification.com Pics and detailed information.
Leave out the space.
Old Jun 10, 2006 | 10:57 PM
S-10 Maniac's Avatar
S-10 Maniac
I took the Power steering box, pump, and column from a 1970 f250 and they bolted right up to my 66.
Old Jun 11, 2006 | 12:26 AM
"Beemer Nut"
Did you have enough clearance for the steering box without changing the left motor perch, installing 70 into a 66 truck?
.....=o&o>.....
cuda66
Mar 25, 2014 07:04 PM
rwrogers
Feb 15, 2014 12:21 PM
1ole4d
Apr 6, 2007 07:14 PM
66f100
Apr 30, 2005 01:32 PM
Brian66
Dec 1, 2003 10:30 PM
