now its slugish
Old May 28, 2006 | 12:56 PM
1970Custom's Avatar
1970Custom
now its slugish
I just got a used set of 33x12.50r15s on 15x10s for my Bronco replacing the 32x11.50r15s on 15x7s.
My Problem is, since I put the new stuff on it doesn't perform like it did with the smaller stuff. Why is this? my pressure is correct all the way around.
I wouldn't think that the small size difference would affect the performance of the truck overall.
Thanks,
Old May 28, 2006 | 01:52 PM
81-F-150-Explorer's Avatar
81-F-150-Explorer
You may need to switch out your Rear end and front end gears to match what you had with the smaller tires.
Larger tires are the equivalent of higher gear ratios, if I remember rightly.
What engine size, and gear ratios are you running?
I can go on forever on why I love high gear ratios, cause of gas mileage, but they can cause problems in the wrong applications. If the truck is lifted, and oversize tires are added for instance.
I could also just be down to the larger surface area on the new tires as well, if applicable. Not too familiar with those tire sizes.
Old May 28, 2006 | 03:12 PM
1970Custom's Avatar
1970Custom
I've got the 4.9/NP435/3.55s.
I wouldn't think that the jump from 32s to 33s would cause this much of a problem.
Old May 28, 2006 | 04:06 PM
littleme13's Avatar
littleme13
its not so much the inch taller but prob thewider contact also what kind of tires did you have before and now if they were different brands they may have much different weights to them also he wider rims weigh more so now to get them rolling is much more work
Old May 28, 2006 | 04:12 PM
1970Custom's Avatar
1970Custom
They're the same tires, just bigger, about the same tread left too, which isn't much.
Took it out just a few min ago and it seemed to be better than it was last night, which is confusing me.
Old May 28, 2006 | 04:17 PM
littleme13's Avatar
littleme13
i would think then that its not the new tires as much as maybe weather conditions or something with the motor. i would try it for a few days and see if it changes or someone else might have a better answer for ya
Old May 28, 2006 | 04:39 PM
havi's Avatar
havi
I'll have the Roast Duck
you'll probably get used to the difference and not notice anymore. Kinda like wearing a new pair of work boots. The "new 1/4" of tread on the heel makes ya walk different for a couple days.
