I need EGR summary
Old May 28, 2006 | 10:58 AM
Jim McCarty's Avatar
Jim McCarty
I need EGR summary
OK, if I disconnect the wires going to the EGR, then I can idle my ’06 6.0L for long periods of time (3 – 4 hours) without high idle and with no ill effects. True or false.
Old May 28, 2006 | 04:34 PM
mjlevi's Avatar
mjlevi
good question!!, I want the same answer !! I just can't imagine that this particular Diesel engine has issues with long idle times, it is my opinion that if you use known good fuel, with good additives, and change your oil often... you can let it idle all you want!! On every fill up I use 16oz. of Diesel Kleen, 16oz. of Marvel Mystery Oil, and 16oz. of Sea Foam...I change my engine oil and Filter every 2500 miles, I use 12qts. Rotella Synthetic 5W-40, 1qt. Marvel Mystery Oil, 16oz. of Lucas Synthetic Oil stabilizer, thats 13.5 qts. total for proper refill amount. I change the Air and Fuel filters every 5000 miles...these intervals assure me that I can run my truck, idle for whenever I want and have no problems!!!!
Old May 28, 2006 | 05:26 PM
vloney's Avatar
vloney
on the late model 6.0 there is no reason to disconnect because the pcm shuts it off for you after 5 minutes
Old May 29, 2006 | 03:28 PM
bnmccoy's Avatar
bnmccoy
I believe the "don't idle for long periods" has to do with "wet stacking" and nothing to do with the EGR.
Not enough velocity through valves at idle; therefore, builds up gunk. I think it was an issue for the 7.3 too but I really don't remember for sure since I never owned a 7.3.
Bob
Old May 29, 2006 | 03:32 PM
bnmccoy's Avatar
bnmccoy
here is an old post describing wet stacking; there is also a link within to another site.
https://www.ford-trucks.com/forums/s...t=wet+stacking
