New valve cover question
Old May 28, 2006 | 12:33 AM
n001pa's Avatar
n001pa
Question New valve cover question
I am in the process of completing a new 390. I have new custom valve covers and and a new air cleaner. My dad brought up the fact that the old engine had the hose running from one of the covers to the cleaner for crank case pressure. I can't run that hose now due to the new parts. Is this something I need to consider or will it be fine without it? The engine has a rv cam and Edelbrock Performer intake and carb.
I know this is probably a stupid question but this is my first rebuild and I want to be sure I do it right.
Old May 28, 2006 | 01:05 AM
Bear 45/70's Avatar
Bear 45/70
You can just run a regular breather on the valve cover away from the PCV valve (you have to run an inlet for the PVC systemand you need to run a PVC system). I actually cut a hole in the bottom of my chrome air cleaner and mounted the hose there on my 1968 F250's 390 I built. Worked fine, but the breather works too.
Old May 28, 2006 | 01:34 AM
n001pa's Avatar
n001pa
I need to get new breather caps for the valve covers. Are you saying that if I get get just the normal breather caps then I'll be ok? What do you mean about the PVC system?
Old May 28, 2006 | 09:42 AM
bertha66's Avatar
bertha66
If your PVC system is hooked up, the hose from the other valve cover goes to the air clearer, most of the after market air cleaners had a way to hook a hose to them, if not you can make a nipple and attach one, if you can not attach one you can put a breather cap on the valve cover, but you will get some oil from this on you engine, the oil that would normally burn in the engine. You can run a hose from the cap to the back of the engine and down and out, but will not pass a smog test.
Old May 28, 2006 | 11:13 AM
Bear 45/70's Avatar
Bear 45/70
Yes, all the breather caps have some sort of filter in them. I prefer the finer filters in the hose system, but the other will work fine.
kenspres
13
Aug 7, 2013 09:16 PM
Quantum77
Nov 8, 2010 07:49 AM
fmc400
Feb 2, 2007 09:15 PM
stegner
Jun 20, 2006 02:05 PM
trinogt
Sep 24, 2002 11:10 PM
