Aluminum Driveshaft
Originally Posted by ford390gashog
the shaft is not aluminum it is infact Stainless Steel 6061-T6 the VP part number lists it as a full stainless steel driveshaft. magnets won't stick to SS so the magnet test is useless here.
6061-T6 is aircraft grade aluminum. I've bought several hundred pieces of it in the last few years. Magnets will "stick" to any ferrous or nickel metal, stainless steel is nothing more than ferrous iron with certain alloys that prevent corrosion, stainless is a misnomer it will rust if not taken care of.
You will never see a stainless steel driveshaft, stainless steel does not have any flexibility and will crack with very low amounts of tension on it. Its pretty but useless.
Aluminum flexes better than steel, doesn't transmit noise like steel, and like stated above is much lighter so it reduces driveline drag.
LB Scab
07 Scab F150 with the 8' box 4x2 Heavy Half (8200 GVW). Have not been under it in a while but from what I remember it looked to be out of steel. Definitely 1 piece drive shaft.
Just a curiosity. My 06 150' wb crew has an aluminum driveshaft. My dads 04 sc has a steel drive shaft.
Any body have any info why they went to the aluminum unit? Same rear in both trucks (3.55 and LS). I have 18's, his 17's and mine is 4x4, his 4x2.
Any thoughts?
It is a one piece DS, in the event that anyone is interested.
Any thoughts?
rigsboo
30
10-22-2015 10:51 PM
Ford4X4ingboy
17
09-23-2014 01:37 PM
