Oil Pressure
Old Feb 25, 2002 | 09:20 PM
AaronW's Avatar
AaronW
Oil Pressure
I changed the oil for the first time since I have owned the truck and the pressure is noticeably lower. I am running 10W-30. No clue how many miles are on the engine, it does use a little oil. Will running a thicker oil, 5W-30 bring the pressure back up? What about adding some Lucas?
Thanks
Aaron
Old Feb 25, 2002 | 10:03 PM
FE427TP's Avatar
FE427TP
Oil Pressure
5w-30 is thinner than 10W30 I run 10W40 in my truck and get about 60pounds@3000RPM what are you getting? a FE 360/390 only needs 6psi to idle according to the original Ford engineers, but that only applies if it picks up immediately with you goose the throttle.
Old Feb 26, 2002 | 04:01 PM
canzus's Avatar
canzus
Oil Pressure
I'm using 15W40 in our '68, which is registering
low anyway, and straight 30 in the '63, which is also
registering low at idle only...
Steve & the Rockette
'63 F100
'68 F100
'72 Capri 2L
'73 Capri 2.6L V6
'73 MG B GT 2.6L V6(Ford)
'98 Contour SVT 2.5L V6 (Mods)
'01 ZX2 (No Mods yet)
Old Feb 26, 2002 | 07:55 PM
TomThrall's Avatar
TomThrall
Oil Pressure
cjgray1974
35
Apr 15, 2013 09:32 AM
1976Ranger
Jul 5, 2012 03:26 PM
dennish
13
Nov 17, 2009 08:28 PM
Itch71
Oil & Lubrication
24
Jan 23, 2008 07:38 PM
Fitzydog
Oct 30, 2003 02:17 AM
