Ambulance needs help
Old May 30, 2006 | 07:05 AM
pmasley's Avatar
pmasley
There is a relay under the hood. I think it is #9. Swap it out with another and see if you get a start.
Old May 30, 2006 | 11:31 AM
Medic 66's Avatar
Medic 66
If I recall correctly, does the #9 under the hood also go hand in hand with the CPS cirucuts and that is the one that HAS to be disconnected before changing it out?
Old May 30, 2006 | 03:10 PM
Powerkleen's Avatar
Powerkleen
I agree with strokin_it7.3
Have you checked the oil level. I had a leak on the oil and it gave some screwy symptoms. It would start and idle fine, act up .5 mile up the road. Let if set for a little while and it would do the same setup again. The oil was low enough that once you started it and then run the pan empty and developed air pockets that it would act up because the oil pressure wasnt there to fire the injectors. At least that is what I was told when it happened to me.
Good luck.
Old May 30, 2006 | 04:39 PM
pmasley's Avatar
pmasley
I never pulled mine, however the batts were disconnected. Anytime I do anything with the electrical componets, I disconnect the batts. Fired one to many computers that way.
Old May 30, 2006 | 08:32 PM
automedic's Avatar
automedic
Update
The oil level is fine. The truck develops oil pressure while cranking. I replaced four of the relays and moved the rest around. This thing is really kicking my tail.. This unit is equipped with a battery shut off and it was off when I chnaged the CPS. I was told that the high pressure fuel regulator may be bad.
Old May 31, 2006 | 07:24 AM
Kwikkordead's Avatar
Kwikkordead
You mean the HPOP? I'm starting to wonder if it didn't give up the ghost.
What's that trick to test it, unplug the IPR and see if it runs?
Old Jun 8, 2006 | 10:24 PM
automedic's Avatar
automedic
ambulance needs help
Well,
Got it running today after we replaced the IPR. One of our mechanics took a class last week offered by Standard products. They basically said that there are three things that will cause this, oil sensor, CPS or the IPR. It's been a battle but it's running good again.
Thanks to everyone for their input and help.
Alan
