Having said that, cutting a LWB down to SWB dimensions will add a lot of extra work & time. In the end all you'd be doing is putting lipstick on a toad.
Start off with a wheelbase you think you want in the first place. Spend your time, effort & cash tweaking & building running gear and suspension the way you'll need it.
I'm no fan of modular engines for several reasons I will not go into here. I'd just suffice it to say There's No Replacement for Displacement,when it comes to making power & torque.The ability to develop, accurately control & plant generated power & torque on the pavement is what wins straight line racing.
Running a built 460 works best for me, the only major improvement I will make on my 460 will be MAFS/ EFI conversion when I get around to doing it. I am disliked by the Brand X-ers and I Drive to & fro & still manage mid 12 ETs @ Huge mph for the ETs I index at. It is way beyond the 5.4 you are thinking of at 7.5L. . . .I know guys running 2.3L [2300cc] engines, and that's just the difference between a 5.4L and 7.5L. . . . .see where this is going?
FBp
thanks for the heads up on the frame shorting guys,,,,,i guess i will keep looking for a short bed
as for the big block motors,,,,yes they are cool
ive had some pretty good luck with my 5.4 modular mill,,,i can get my 4700lb beast down the track in the very low 11's with it,,i have hit the 10's with a little nos
and the 16mpg aint to bad either
although with a big block i probably would not need a blower,,ha ha
I agree with you on the torque. However, the modulars are amazing motors. For my 98 weighing in at around 5500 lbs and only having the 4.6L, it does quite well. If I lined up my 390 and my little 4.6, I know that the 4.6L would blow the doors off of the 390 (stock for stock, of course). I'm not sure what a stock 390 puts out for torque, but I think it's about 255 hp at the flywheel. A 5.4L puts out 260 hp and 345 ft lbs - stock, and with 60 less cubes. Just imagine what a blower would do on that 5.4L!!!!
Bottom line is do what you want. It's YOUR truck not ours. It will be more expensive to put a modular in as opposed to a 390 or a 460. I feel that all of these are good motors, and you can't go wrong with any of them. By the way, I love the 390 and plan to build a stout one for the 69 someday.
Those modular motors will do anything you ask them to do, and it will be a neat swap! I've never played with one, but I'm familiar with FE's.
instig8r63 is right on the longer wheelbase being easier to drag race with, but I don't think you're going to notice the difference with a street driven truck.
You could buy a longbed, chop it down, and build or buy (if you can find one? usbody) a fiberglass bed. It might not help your traction situation. Good luck.
thats what i was thinking,,,besides the extra length is there any other difrences between the 2 frames?
im gonna have a difrent then stock fuel cell,rear suspension, rear drive and drive shaft,,,and if i got a fiberglass bed,,,,,what would the benifit of getting a short bed instead of a long bed?
You do not want to cut one down. You would have to make 4 cuts from sun rise to sun set and two welds the same, because you would have to shorten it in both front and rear of the wheelwell. Two body side seams that have to be made to look decent. If you want a short bed find and buy one. You will spend ten time more trying to make one. IMHO
I guess my post wasn't that clear. Buy a longbed, cut down the frame, build a fiberglass shortbed or buy a shortbed. Don't cut up a longbed bed. THat would suck to weld together again. Good luck with whatever you decide.
thanks for your info,,,im a knouckle draggin gear head,,,,it has to be crystal clear,,,lol
Short beds are much more popular...around here anyway. can't find many longbeds.
My shortbed is my hot rod, my long bed is the usable daily driver. I hate shortbeds cause they are useless for carrying anything....other than haul'n butt!!
