Edge Problem?
Old May 26, 2006 | 03:38 PM
the4by4freek's Avatar
the4by4freek
Edge Problem?
While I was fueling up this afternoon I figured it would be a good time to change some settings on My Edge. When it finished programming I started the truck back up and the fuel gauge was reading the same as it was before I put gas in it. I have not tried returning to stock yet to see if it fixes the problem. Does anyone else have any ideas about this?
Old May 26, 2006 | 05:28 PM
InboundFX4's Avatar
InboundFX4
Has it corrected itself yet? Im not sure this would be an Edge problem. I recall reading something in the truck manual about turning the key off when filling up so the sensor can read the correct level of fuel.
Old May 26, 2006 | 06:15 PM
the4by4freek
It has corrected itself I think. It came up really slow. I did have the key on while filling because I was reprogramming my EDGE at the same time (multi tasking) I turned the truck off and restarted and it still didn't move. IT has come up to 3/4 tank now. I think it is right. I put $50 in the tank and had about 1/4 left. It should be really damn close if not perfect. I'll see when I get out of work tonight at 9:00
Old May 29, 2006 | 12:27 AM
GotBeer's Avatar
GotBeer
Its not the edge, its from having the key on while refueling. I had the same thing (was listening to stereo) happen awhile ago. Took it to the dealer and that is what they told me.
