3.0 stroker?
Old May 26, 2006 | 06:43 AM
67blueford's Avatar
67blueford
3.0 stroker?
I have a 97 ranger with the little 3.0 in it ... Ive seen stroker kits for all sorts of motors but I havnt found any for the ranger 3.0 .... Would the crank out of a 3.8 work to stroke the 3.0? If anyone has any ideas or any contacts that could help me please let me know.
Old Jun 2, 2006 | 02:39 PM
wendell borror's Avatar
wendell borror
The easest way to stroke it, would be to swap in a 4.0, there is really nothing out there for the 3.0 to speak of. The 3.8 is a different animal, parts won't interchange. If anybody could help, it would be supersix motorsports, give them a look see.
Old Jun 6, 2006 | 08:28 PM
bryan_johnson's Avatar
bryan_johnson
If you look it up online, Morana V6 Racing has a 3.3L stroker kit for the Vulcan, I just inquired about it last week.
Old Jun 7, 2006 | 06:27 AM
3Lstroker's Avatar
3Lstroker
Unless your pockets are alot deeper than mine and you have 4k burning a hole in your pocket, the cheapest thing you can do is a "poor mans stroker". I had a reputible shop offset grind the rod journals .025" and another .005" for cleanup and am running .030" under rod bearings. With a .030" over bore, it comes out to 3.1 liters, with 0.0" deck height, and calculates out to about 10:1 compression(aka premium fuel). I am running a Cam Craft regrind cam at 210/210 @ .050" duration with .470" lift at the valve. I have not had it on the dyno since I took out the pos a4ld trans and put in the 5 spd, but I talked to a guy that works at the Ford Lima plant a few months ago, and he assured me that with my setup I am at or just over 200 ponies. Best part about it is I get 23 mpg's in town with the stick trans!!
Old Jun 7, 2006 | 06:48 AM
wendell borror
It still seems cheaper to me just to swap in a 4.0, and there's alot more performace stuff for the 4.0 as well. You could even do the 4.0 cammer motor cheaper since they have been using them in the exploder since 97, or 98 I believe. At 207 hp, thats about the same as a stock 5.0, not as much torque but it does come on sooner.
Old Jun 10, 2006 | 08:17 AM
Pablo-UA's Avatar
Pablo-UA
67blueford! 3.8 is wide, but narrow. It was disighned for low cars, but some parts are interchangeble (see part nombers). It is possible to use Mercedes pistols and cylinders to increase HP of 3.0 (of cource it will be 3.4 ore 3.6 engine), but these parts are avaliable in Europe. ANd this operation requires many modifications (to describe modifications I need 3-5 pages). But there are many aftermarket parts to increase HP of 3.0. The first step - to use raicing camshaft and dual valve springs, the next step - rebalance crankshaft and rods, the next - use light pistols (original size is 88.9 mm 96 is limit for this engine, and remember if you have 96mm pistols, block may crack in case of overheating, so the engine is not reliable enought).
Wanna more? K&N intake + powerchip!
Next step - manual tranny.
Old Nov 23, 2006 | 02:22 PM
papa's 64's Avatar
papa's 64
there's alot more to doing a 3.0 to 4.0 swap. trans, wiring harness, motor mounts,computer. all of this is different and would have to be changed it would be easier to get a new truck that had a 4.0 in it. just my opinion
Old Nov 23, 2006 | 02:52 PM
RangerPilot's Avatar
RangerPilot
Or...rip it out and go carbed 5.0L.
Scratch that, he lives in Texas.
Old Nov 23, 2006 | 03:33 PM
papa's 64's Avatar
papa's 64
that woud be easier than a 4.0 swap
Old Nov 24, 2006 | 12:35 AM
RangerPilot
Yeah...it would. But Texas is pretty retarded. It has to be a newer engine than the one being swapped out, which limits him to EFI only, and still pass inspection including emissions.
Been there...done that. Got a beautiful 302 getting ready to go for my Ranger if I can ever find a hole in the laws.
Old Nov 24, 2006 | 01:20 PM
78ltd's Avatar
78ltd
Texas
Unless he lives here in Wichita Falls or a small farming
community. We don't have emission testing. The engine
swap field is wide open here.
Old Nov 24, 2006 | 02:40 PM
RangerPilot
Oh you lucky son of a gun.
I get sniffed every year, it's a city thing though. Dallas, Houston, etc. Of course I live in Collin county, which is right on the border, the counties next to us don't have it.
It's the one thing holding me back from going pretty much all out with this 302 swap.
Old Nov 24, 2006 | 04:16 PM
78ltd's Avatar
78ltd
Emmisions
Well, as I drive for JB Hunt out of Dallas and love to hit all the half-price books in the area, I sometimes wonder how long it will be before the various cities start mailing me tickets. I'm currently driving a 74 Mercury Montego that's been in my family since new and sometimes at various intersections, especially around 635, Dallas has they're portable sniffers set up. I may have to start killing the engine and coasting past. Not that I'm a gross polluter (the car has all it's emissions gear hooked up), but with the cities hurting for money, they might one day start sending tickets to out of towners! Of course, I think all 25 year old vehicles are exempt from emissions.
FORD4LYF
Sep 4, 2015 09:24 PM
kbrady 1952
Engine Swaps
May 19, 2015 09:34 AM
61_racer
3.0L V6
May 15, 2015 05:34 PM
lilwrkmstr
1983 - 2012 Ranger & B-Series
Sep 15, 2008 06:54 PM
blot0
3.0L V6
Jun 25, 2003 12:55 AM
