Fuel bleeder valve leaking
Old May 25, 2006 | 03:35 AM
Dannym's Avatar
Dannym
I found the fuel injector rail bleeder valve- the schrader valve on top of the rail- is leaking slightly on my '87 302 EFI. I've already turned the key a few times and immediately popped the valve to try to spray out any debris that may be sticking it open, no luck.
What can I do about this? I tried to do a parts search on partsamerica.com and didn't see anything but grommets for fuel injectors. Is there a fuel-compatible ring I can replace here or am I going to have to replace the whole valve?
Old May 25, 2006 | 08:55 PM
1pump's Avatar
1pump
Should be similar to what A/C uses on their schrader valves. Most parts stores (real ones) should have cores for 'em.
CaptainFacePunch
Aug 6, 2015 08:29 PM
jb50F1
Feb 1, 2014 12:54 PM
TileDude
Sep 28, 2012 11:23 AM
network
Jan 23, 2006 03:03 PM
