V-10 w/ Cherry Bombs ?!?!!!
Old May 24, 2006 | 06:16 PM
devildog_0431's Avatar
devildog_0431
Talking V-10 w/ Cherry Bombs ?!?!!!
My trucks is a 99 F-250 SD w/ the 6.8L V-10. Currently I am running a single in dual out Flowmaster Super 50 w/ 6 in tips. I have the stock primary and secondary Cats still. I was wondering how much better this truck will sound If I cut off the Muffler and make a single in dual out coupler to the 2 cherry bombs, I'm thinkin 3 footers. I know these V-10's need back pressure to run well so I think w/ the 2 cats and the 2 glasspacks it should be okay.....
Old May 24, 2006 | 08:55 PM
kens64's Avatar
kens64
Originally Posted by devildog_0431
I know these V-10's need back pressure to run well....
How do you know that?
Old May 24, 2006 | 10:10 PM
TP83's Avatar
TP83
low end torque if that has anything to do with it.
Old May 24, 2006 | 10:40 PM
seventyseven250's Avatar
seventyseven250
I've yet to hear anybody explain why an engine needs backpressure for low end (or any other reason). Surely someone somewhere has done back-to-back dyno pulls to prove this or something?
Myself, I don't believe it.
Old May 24, 2006 | 10:47 PM
kens64's Avatar
kens64
Thats because an engine doesnt need backpressure. Backpressure is restriction, nothing more. Exhaust velocity is far more important.
Old May 25, 2006 | 01:17 AM
V10man's Avatar
V10man
The V10's didn't get dual cats until 2005. You should have one huge cat. There is no need to dual out the exhaust after the cat. It only goes to looks and sound.
Old May 25, 2006 | 06:55 AM
Sycostang67's Avatar
Sycostang67
Why such long glasspacks? I would go with a couple 12" glasspacks to get a little more sound. The cats already do most of the muffling. I went from the factory exhaust on my F-250 to dual 2.5" pipe with no mufflers, (no cats required ) and stacks that are 5" x 60", and I didn't notice any lag in performance.
Old May 25, 2006 | 04:56 PM
devildog_0431
I have 3 buddies w/ the F-250 SD's and they told me they got straight pipes on their V-10's...sounded good but they were hard to start and ran like **** after they had the pipes put on, 1 guy went back to stock while the other two went to flowmaster. Even the worker at the Muffler Shop agrees to only put y pipes on these trucks and always have the cat.
so will 2 cherry bombs sound better than my 50 series muffler ?
Old May 27, 2006 | 01:55 PM
KubotaOrange76's Avatar
KubotaOrange76
Its Comin Right for us!
velocity is what matters not back pressure
http://superchevy.com/technical/engi...t/0505phr_exh/
kwztoy
Mar 15, 2013 10:01 PM
TractorMaster96
Jan 27, 2013 10:40 PM
70torino429
Apr 18, 2010 12:01 PM
tkeduck
Nov 22, 2009 09:16 PM
