1978 - 1996 Big Bronco
rotors with ABS replacement
Old May 24, 2006 | 04:30 PM
RA81222's Avatar
RA81222
I read some old posts on this and do not have the $ to get the whole replacement unit so I need to get the rotors and get that ABS ring off. Is the best way to knock out the lugs and use them to drive off the ring or can I use a big 3 jaw puller somehow?If I use the 3 jaw puller I guess I would have to lay a piece of steel across were the grease seal is so the center bolt on the puller has somehting to put pressure on correct?Also, I guess The dpth that it goes back on is critical also?Thanks
Old May 24, 2006 | 06:28 PM
broncobob's Avatar
broncobob
I used a puller on my 94 when I changed the rotors, the ring isn't very hard to pull that way. I used a large socket in the center to push against, and the ring popped off with very little force required. Putting it back on went pretty easy too, just used a press to press it on, make sure it's straight and take your time.
Old May 24, 2006 | 06:30 PM
andym's Avatar
andym
I know money might be tight, but you'll be much happier if you buy the whole replacement rotor. If you don't, putting the rotor back on the hub is a huge pain, you'll warp the rotor for sure. You MUST have them turned before you install them if you go that route.
Been there, done that, my two cents, etc, etc.
Old May 24, 2006 | 07:32 PM
RA81222's Avatar
RA81222
what kind of press do I need for the ring?I have changed rotors on my 89' in the past without warping them, but that one did not have the ABS ring to mess with.
Old May 25, 2006 | 07:16 AM
broncobob's Avatar
broncobob
I just used my hydraulic shop press to put the ring back on because it was handy, you can tap it back on with a hammer and block if you're careful and make sure you keep everything straight. Other than the ring, everything else should go just like your 89, not too bad a job.
glovemeister
Jul 9, 2014 04:43 PM
tbsexc
May 31, 2012 09:39 PM
jaserlet
Nov 9, 2011 03:42 PM
pvatki
1983 - 2012 Ranger & B-Series
Sep 24, 2009 11:21 PM
c_hohensee
Feb 12, 2006 07:19 AM
