Couple Questions
Old Jul 9, 2014 | 02:10 PM
glovemeister's Avatar
glovemeister
Couple Questions
What are you guys doing to grease a spindle bearing, d60 4x4?
Is the procedure the same as wheel bearing? Just pack the rollers real good and thats it?
Lastly what are you guys using to remove a steering wheel on these trucks? I took the horn pad off the other day and discovered two unthreaded holes so the standard threaded puller won't work. A jaw puller also doesn't seem like it would work. Need to get it off to rebuild my column.
Thanks
Old Jul 9, 2014 | 04:10 PM
ReBilld's Avatar
ReBilld
Yes, just pack the spindle bearing like the wheel bearing. And for the steering wheel, I loosen the bolt and back it out about half way, then put my knees behind the wheel and push it toward me with my legs while I hit the bolt with a large punch and hammer. Most of time they will pop loose after a couple good blows, but depending on how tight somebody tightened the bolt, it may take several. I don't know why, but some of these steering wheels have pull holes and some don't. If yours has holes that aren't tapped, maybe you could run a tap in them and use a puller.
Old Jul 9, 2014 | 04:43 PM
madpogue's Avatar
madpogue
Some steering wheel pullers have j-hooks for the unthreaded holes; maybe your FLAPS has one to lend.
Chris Skoglun
16
Oct 21, 2022 09:36 AM
nagetech
Jul 16, 2015 03:31 PM
burnout400m
Nov 18, 2012 02:19 PM
Martin Broll
Jan 10, 2009 11:32 AM
