Surging Problem
Old May 24, 2006 | 04:20 PM
sharky's Avatar
sharky
Surging Problem
I have a 96 psd with 78,000 miles and I have a problem with it surging after it warms up. It doesent matter if I am driving on freeway or in town but it seems to do it when i am at a constant speed. The surge isnt huge maybe 200 to 400 rpm. the oil has been replaced and fuel filter changed with no help.
Old May 25, 2006 | 07:57 AM
plowhand's Avatar
plowhand
Playing in the Dirt
The CPS will cause this sometimes, also check the timmerman nut on the IPR, located on the left rear bottom of the HPOP, if it is loose it will cause the oil pressure to the injectors to go up & down. Check your fuel pressure on the FPR at the schrader valve (should be between 40-60 psi stock, anything under 16 will cause injector miss fire).
Old May 25, 2006 | 08:08 PM
sharky's Avatar
sharky
cps
is that crankshaft or camshaft sensor?
Old May 26, 2006 | 05:33 AM
Cuda_jim's Avatar
Cuda_jim
CPS = Cam position sensor. I don't think the PSD has a Crank sensor.
Do a search for CPS. you will get alot of info on the subject.
JIM
Old Dec 8, 2006 | 06:32 PM
cemsawmill's Avatar
cemsawmill
surging
clean your fuel regulator screen, the post for how is here just look for it. I was having the same problem and when I cleaned mine it was totaly pluged off. what a driffernce it made. cem
