Is this normal?
Old Dec 8, 2006 | 02:37 PM
tlbranth's Avatar
tlbranth
Is this normal?
I have a 1996 f250 diesel (rebuilt from a rollover). It runs fine but when I first start it, the charging system doesn't kick in for several minutes - has nothing to do with engine speed either. After 2 or 3 minutes (I'm estimating here), the voltage goes up to where it belongs. Is this normal? If not, any ideas?
Old Dec 8, 2006 | 03:14 PM
94.5turbodiesel's Avatar
94.5turbodiesel
What you are seeing is normal glow plug operation on the charging system. It takes a couple minutes for the glow plugs to cycle each startup.
Old Dec 8, 2006 | 03:46 PM
utahcrew's Avatar
utahcrew
yep, glow plugs. takes 120 sec.(two min)
Old Dec 8, 2006 | 05:13 PM
ckal704's Avatar
ckal704
The owners manual suggest you not load up the electrical system with headlights and heater fan, etc. while the glowplugs are energized.
But that doesn't make a lot of sense to me since you have probably over 800 CCA from 2 batteries in parallel circuit and the plugs are only on a couple of minutes.
I start up and turn my lights and heater on and drive away. I figure a little extra load on the alternator puts a little (yes, very little, I know) extra load on the engine and the engine doesn't really start warming up unless it is under some load anyway.
Old Dec 8, 2006 | 06:40 PM
tlbranth's Avatar
tlbranth
Thanks for the responses. I thought once the thing started plugs weren't on anymore - seems like it'd only help if the alternator helped out - but wadda I know. Thanks again.
