Possessed truck
Old May 24, 2006 | 12:20 PM
BeltDriven's Avatar
BeltDriven
Possessed truck
I go to start my truck today and it started fine but the starter kept spinning.
I turned the ignition off and the starter is still spinning and eventually catches the fly wheel and the engine starts to turn…. WOW!!! 84 I6 manual.
<!--[if !supportEmptyParas]--> <!--[endif]--><o></o>
Any thoughts?
Old May 24, 2006 | 12:32 PM
quicklook2's Avatar
quicklook2
you need a new starter.
Old May 24, 2006 | 01:48 PM
81-F-150-Explorer's Avatar
81-F-150-Explorer
Sounds like the starter solenoid is in a partway stuck position. The question is why...
Remove the start wire that comes from the ignition switch, that's plugged onto the solenoid.
Then check to see if there is power going through the solenoid by checking the back terminal, that leads to the starter. If you get ANY amount of power through here, replace the solenoid.
Then check the start wire from the ignition switch, that hooks up to the solenoid. With the switch in the off position, if the wire is hot, check wires and/or replace ignition switch.
If the starter engaged the flywheel for too long, the starter's gear could also be toasted, and needs to be replaced. Also you may need a new flywheel if it got damaged. Check the state of the teeth, when you have the starter removed.
Hope this helps
Old May 24, 2006 | 07:17 PM
F250FarmBoy's Avatar
F250FarmBoy
That is the same thing that happened on my classic John Deere tractor. I would press on the starter pedal and it would do the same thing you're talking about. It would only stop if I disconnected the battery. The problem was the rod that starts the starter was grounding with the starter itself. Ohhh wait, thats not how truck starters work....is it. LOL!
Old May 24, 2006 | 08:21 PM
83Van's Avatar
83Van
Same thing happened to my van. Started it but the starter stayed engaged, cut the key off and it kept cranking. The starter solenoid up by the battery was worn [20 years worth] and the contacts "stuck" making it run on and on and on. Had to smack it with a handy piece of wood to get it to stop.
The solenoid is a cheap part [$10-$15] and easy to replace. Hopefully the episode didn't kill your starter. Mine died about two weeks later from cranking for a good minute solid... its guts were pretty toasty. The bearings were also a bit loose from spinning at ~1200 rpm for several seconds while the engine was running.
Old May 25, 2006 | 08:53 AM
BeltDriven's Avatar
BeltDriven
I have a new solenoid ill put on then check the starter. The only things I have done to the truck are installed a new clutch kit, new flywheel (koi had a deal on them) rear main. Also near the solenoid there was some corroded wires I replaced (orange and green wire spliced to a yellow wire) one is ignition the other is headlights.
I have been putting a lot of stress on the solenoid due to a bad carb and trying to get the truck running so hopefully my problem stops there.
Thanks for all the great input,
Don
gmcco
Apr 9, 2009 12:50 PM
Slamdunkpro
Aug 21, 2006 07:55 PM
dfranke
Jul 27, 2005 11:54 PM
sneak
Jul 1, 2005 12:42 PM
jd_sylvia
Apr 17, 2005 10:11 AM
