Biodiesel
Old May 24, 2006 | 10:14 AM
minnichjr's Avatar
minnichjr
Question Biodiesel
First time here. Has anyone used biodiesel in they're 6.0 diesel? If so did it effect the engine in any way?
Old May 24, 2006 | 11:45 AM
JRM6868's Avatar
JRM6868
Welcome to FTE! I haven't used it but I believe Ford only recommends a B5 which is only 5% to diesel mix.
Old May 24, 2006 | 11:47 AM
bigredtruckmi's Avatar
bigredtruckmi
Veteran: Navy
I have been using it in my 04 ever since new. No ill effects - runs great. I use a commercial soydiesel from this company with these specs https://www.crystalflash.com/files/C...iesel%20XC.jpg
cetane I have found over the years has a lot of effect on my 04 and my 93. This is from personal observation. I would keep with a fuel with a cetane of 45 min.
Old May 24, 2006 | 03:59 PM
BPofMD's Avatar
BPofMD
Veteran: Navy
Bad Link...for me anyway.
Old May 24, 2006 | 04:29 PM
kw5413's Avatar
kw5413
Welcome to FTE and the 6.0 forum minnichjr
When you get a chance you might want to cruise over to our Tech Folder for some great 6.0 info.
https://www.ford-trucks.com/forums/showthread.php?t=303583
Please take a few moments to read our site guidelines as well.
https://www.ford-trucks.com/guidelines.html
Old May 24, 2006 | 04:31 PM
kw5413's Avatar
kw5413
Go to this FTE forum for more Bio info:
https://www.ford-trucks.com/forums/f...play.php?f=168
Good luck.
Old May 24, 2006 | 07:10 PM
phish555's Avatar
phish555
Ive used it im my 06 6.0, couldnt tell the difference. I might have gotten about 1mpg better fuel economy. Hard to tell cause I did a lot of city driving. Costs about 10c more per gallon here, but don't have to add a fuel additive.
Phish555
06 F250 ps superduty
Old May 24, 2006 | 07:21 PM
bigredtruckmi
Veteran: Navy
Apparently the FTE link to a pdf file doesn't work right. Here is another http://www.crystalflash.com/products.vml Then go to 8)crystal Flash Soy Diesel XC Hope this one works... Doesn't work but Go to fuels on side tab then go to pulldown menu go to fuels again. then go to #8
