C4AE-A Block make 428?
Old May 24, 2006 | 08:53 AM
BBF250's Avatar
BBF250
I've got my eye on a C4AE-A block that has the outer edges cast for 427 cross bolts. Does anyone have experience boring this block?
It looks like the one on ebay item number: 8067282535
http://cgi.ebay.com/ebaymotors/FORD-...spagenameZWDVW
I'm really wondering if this can be bored to 4.13 to make a 428.
Old May 24, 2006 | 10:36 AM
rusty70f100's Avatar
rusty70f100
A C4AE-A number really means nothing. It was used on:
352's
427 top oilers
330HD and larger FT truck motors
Your best bet is to measure the existing cylinder bore diameter to see what you've got now, then go to a machine shop and have the cylinder walls sonic tested. That way you'll know exactly how thick the cylinder walls are.
Old May 24, 2006 | 11:13 AM
FFR428's Avatar
FFR428
Needsmorecoffee.
Lot's of 64 blocks have the crossbolt bosses cast into them. As Kurt said could be a 427, 390, 352 or 330 block. Also 406 service blocks used the same casting number. Try the drill bit test on the cyl wall cores.
G.
Fatblockford
Feb 19, 2016 08:51 PM
KO1960
Jul 23, 2011 06:16 PM
66_in_ky
21
Oct 5, 2010 12:41 AM
gearhed1971
Mar 9, 2010 08:07 AM
C5AE-A
Sep 23, 2008 10:29 PM
