Here we go again, 44,000 miles and transmision #3 from Ford is leaking fluid out the front (only) after it warms up, not when its cold. I have alot of mods on the truck, so I don't know it they will warranty it. Trans acts okay other then that. Any ideas?
Thanks
02 F-350
AIH delete
Kwik filter
4 inch MBRP exhaust sys
Predator chip 70 hp/ 120 tq lb
Map line mod
T/C lock up switch
HPX cross over
my 3rd trans from ford has always leaked under load only at low speeds hauling 11,000lbs,but now it leaks all the time after warm up and I keep the fluid level correct
Put everything back to as close to stock as possible and take it in,,They notice any tuner mods and you can probably forget about any warranty on the tranny.
No I dont have a trans temp gauge but felt the fluid coming out and it was not hot.I also notice that it doesnt leak much at freeway speeds mostly in town and when you stop and the gauge on the dash never changes.
