trans problem help!
Old May 24, 2006 | 08:43 AM
hirschdale350's Avatar
hirschdale350
trans problem help!
Here we go again, 44,000 miles and transmision #3 from Ford is leaking fluid out the front (only) after it warms up, not when its cold. I have alot of mods on the truck, so I don't know it they will warranty it. Trans acts okay other then that. Any ideas?
Thanks
02 F-350
AIH delete
Kwik filter
4 inch MBRP exhaust sys
Predator chip 70 hp/ 120 tq lb
Map line mod
T/C lock up switch
HPX cross over
Old May 24, 2006 | 10:18 AM
roaky81's Avatar
roaky81
Was the fluid level correct when the tranny was up to temp?
Old May 24, 2006 | 12:19 PM
Fords4Me's Avatar
Fords4Me
Puking out the front seal. A really inexpensive piece, lots of labor to install.
The first time you saw this was it from backing a heavy load or up a steep grade? in otherwords in reverse under high load?
The front seal failing is not uncommon.
Old May 25, 2006 | 08:26 AM
hirschdale350
my 3rd trans from ford has always leaked under load only at low speeds hauling 11,000lbs,but now it leaks all the time after warm up and I keep the fluid level correct
Old May 27, 2006 | 02:13 AM
MRBASS's Avatar
MRBASS
Put everything back to as close to stock as possible and take it in,,They notice any tuner mods and you can probably forget about any warranty on the tranny.
Old May 27, 2006 | 07:45 AM
Thumper4995's Avatar
Thumper4995
Do you have a trans temp gauge? If so, what temp are you calling "warmed up?"
Old May 27, 2006 | 10:36 AM
hirschdale350
No I dont have a trans temp gauge but felt the fluid coming out and it was not hot.I also notice that it doesnt leak much at freeway speeds mostly in town and when you stop and the gauge on the dash never changes.
