A/C compressor cycling
Old May 24, 2006 | 07:48 AM
drb3170's Avatar
drb3170
I have an '06 5.3. Is it normal for the a/c compressor to cycle on and off every 20-30 seconds? The clicking noise it makes when I am going down the highway is driving me crazy. Wanted to get some opinions before I went to dealer. Thanks.
Old May 24, 2006 | 07:59 AM
drb3170's Avatar
drb3170
Oops! I meant a 5.4.
Old May 24, 2006 | 08:42 AM
ford9c's Avatar
ford9c
It could be normal, my 04 does it at times. You need to see if your AC still blows cold in hot weather. If not and your still under warranty bring it in to the dealer and have them evac and recharge the system. They did that to mine and it blows colder then when I first got it. However its by no means the coldest AC system even when its working properly. I heard the 07 f150 is getting a bigger AC compressor to help in that area.
Old May 24, 2006 | 09:40 PM
xtrm1stang's Avatar
xtrm1stang
it is normal for it to cycle like that, it will cycle faster in max ac(recirculate) than in normal ac(fresh air), and it will cycle faster the slower the blower speed is. if it is blowing cold, then all is well, if it didn't cycle it would freeze the evaporator and you would loose ac
Old May 31, 2006 | 09:31 PM
Mikec35's Avatar
Mikec35
Mine was cycling too frequently and the dealer said it was overcharged. They evacuated the system, recharged and its ok now...
Old Jun 14, 2006 | 04:24 PM
amdk62's Avatar
amdk62
Lucky
Be happy that it's cycling evrey 20-30 seconds... My 04 F150 5.4 cycles about evrey 7-10. I'm told by the dealer that is is perfectly normal. I half way wouln't mind the cycling if it made the cabin cold ... To bad is dosen't!
Old Jun 15, 2006 | 05:54 AM
DJR 17's Avatar
DJR 17
Correct me if I'm wrong, but isn't the cycling caused by a low pressure switch? Wouldn't it be running low on refrigerant? It's sounds like something is wrong. I just got my truck yesterday and here in Texas it's been extremely hot(about 104) and I noticed my compressor was making a different clatter than I'm used to. However it wasn't short cycling, or cycling at all. I would put it on max a/c and turn it all the way down, if it still short cycles have another dealer check it out. I haven't checked, but do these trucks have a sight glass? Thats the best way to tell if it's charged or not.
Old Jun 15, 2006 | 10:04 PM
johntucker09's Avatar
johntucker09
I put a few ounces of 134a in my truck tonight...I swear it dropped a good ten degrees in the cabin...
ruffneck30
Feb 9, 2013 09:06 PM
jeff gammon
Aug 4, 2009 11:56 PM
Aerocook
Aerostar
17
Jul 10, 2008 09:58 AM
lumbermansvo
Feb 19, 2007 09:09 AM
T_Moss
Apr 25, 2006 07:29 PM
