Fixed vs. Variable high-speed air bleeder - 2150
Old May 23, 2006 | 10:14 PM
farmnaggie's Avatar
farmnaggie
Question Fixed vs. Variable high-speed air bleeder - 2150
I posted this in the carb forum, but haven't had any takers yet.
I recently acquired a 2150; actually I acquired the entire truck...a '79 F150, 351M, C6. I'd like to use the carb off of it because it is a stock original, meaning it is a '79 model carb. My truck (also a '79) has a 2150 off of a '77 truck. Something done by the PO. Anyway, I started rebuilding it and noticed that it has the fixed high-speed air bleed instead of the variable high-speed air bleed that my '77 has. From what I've read so far, I would be better off with the variable air bleed venturi cluster. I really wanted to have a '79 model carb on my '79 truck, call me ****. What would some of you do if given the choice? The newer carb also has the hot idle compensator on top of the airhorn that my '77 carb does not and it has an electric assist choke that I really want to use.
I'm not exactly savvy in the differences between fixed and variable air bleed systems. I could really use the pros and cons between the two. Something else to consider is that I have a high-pitched whistle created by a worn throttle shaft on my '77 carb that I was hoping to eliminate by switching to the '79 carb. Just another reason I really want to make the change.
Old May 23, 2006 | 10:26 PM
Mil1ion's Avatar
Mil1ion
This is more of a carb (fuel delivery) question than a 73-79 Truck Question.
Do you have the numbers off this carb?
I would like to check it out.
Old May 23, 2006 | 11:02 PM
farmnaggie's Avatar
farmnaggie
Without looking, and going from memory: FED D9TLE ALB
Old May 23, 2006 | 11:04 PM
farmnaggie's Avatar
farmnaggie
Correction... FED D9TE ALB
Old May 25, 2006 | 09:10 AM
Mil1ion's Avatar
Mil1ion
As mentioned on the Private message,
That carb was used extensively ie:On 79 302,330,351M/400 applications
Regarding air bleed carbs
I decided to look on the net for a professional opinion.
I found this.
http://www.carcraft.com/techarticles/81958/
Old May 25, 2006 | 10:05 AM
farmnaggie's Avatar
farmnaggie
Thank you for that info. and the link. I'll give the newer carb a spin and see how she performs.
sailfast3r
Aug 15, 2015 07:39 PM
BBBTruck
Jul 26, 2015 11:03 AM
RustyOldFord***
Apr 22, 2015 02:20 AM
martyanderson10
Large Truck
Mar 15, 2015 10:38 PM
jaredm_k
Feb 10, 2015 08:12 AM
