e-85 in a 03 4.0
Old May 23, 2006 | 08:36 PM
bowman65's Avatar
bowman65
e-85 in a 03 4.0
Does anyone know if I can burn e-85 in my 03 ranger with the 4.0.
Old May 23, 2006 | 08:48 PM
travlnman's Avatar
travlnman
While I'm not sure, I don't think so. Your vehicle has to be specifically prepared to burn e-85. The 3.0ffv can, the standard 3.0 cannot. I don't think the 4.0 has ever been configured to burn e-85.
I have been known to be wrong before, but just check your owner's manual, if there is nothing about it in there, then you can't.
Old May 23, 2006 | 09:32 PM
rkelachim1's Avatar
rkelachim1
No, you cannot run E85 in the 4.0L
Old May 23, 2006 | 09:59 PM
RangerPilot's Avatar
RangerPilot
Right on.
With the proper modifcations, yes it can be done. But it's not worth it, honestly. Especially with some of the issues popping up lately with E-85 (visit the general discussion forum).
RP
Zach
Old May 24, 2006 | 12:54 AM
natebaker's Avatar
natebaker
If you wanted to use the E85 ethanol mix, you'd have to put new cylinder walls, new pistons, new heads, everything would have to be new and made from a different material to withstand the extreme corrosion that would be a by-product. So, it's possible, but not feasible.
Old May 24, 2006 | 05:56 AM
Bob Ayers's Avatar
Bob Ayers
Not true, here are some of the differences between the 3.0L, and 3.0L FFV:
1) Stainless steel fuel lines
2) Higher flow injectors
3) Alcohol sensor in fuel line (along with different PCM)
- modified timing and fuel mixture tables when E-85 is detected
Old May 24, 2006 | 09:31 AM
natebaker's Avatar
natebaker
Hmm, I thought I saw something to that extent in a post about a week ago. My mistake!
Old May 24, 2006 | 10:05 AM
99F150's Avatar
99F150
A good chance that your 2003 4.0L V6 can run E85. You need to check the vin code 8th digit in Ranger is code "V" although I think that is for the 1998-2002 3.0V6 in an Explorer with the 4.0V6 it is code "K"
Check the owners manual, and the fuel door may have a sticker.
Old May 24, 2006 | 10:11 AM
rkelachim1's Avatar
rkelachim1
There is NO chance that your 4.0L Ranger will run on E85.
Old May 24, 2006 | 03:41 PM
natebaker's Avatar
natebaker
That'd be nice. I'd like to have a FFV 4.0
Old May 24, 2006 | 05:34 PM
bowman65's Avatar
bowman65
Thanks, Mine is a fwd, and can pass anything on the road except a gas station. Was just looking for a way to save a little money.
Old May 24, 2006 | 05:50 PM
wendell borror's Avatar
wendell borror
George Walker said on tv awhile back, that in the future it won't cost much to have a vehicle converted to E85, I don't know if he meant that the gov will help with cost, or it just won't cost much, either way, I'm interested. I'm tired of sending half of my paycheck to Iran, or where ever, we need to get away from foreign oil !!!!
Old May 25, 2006 | 06:51 AM
PSKSAM2's Avatar
PSKSAM2
You mean Canada. Largest single country supplier to the US in the six months from Sep-05 to Feb-06. (Granted we get about double Canada's from all of OPEC combined). If the Iraq war was for oil, we should have just invaded our neighbor to the North. Just kidding, guys.
http://tonto.eia.doe.gov/dnav/pet/pe...im0_mbbl_m.htm
The more I read about ethanol, the more I realize that it won't be a real competitor until we in the US learn to make it efficiently by fermenting leftover biomass, or a cheaper crop to grow like sugar cane (as in Brazil) than corn. It'll be interesting to see if any politicians come to that conclusion instead of following the farm lobbies and pushing corn as the ultimate solution.
I don't think you'll see an aftermarket EPA approved conversion kit until gasoline goes $5/gallon or more with no sign of relief. It'd be interesting if Ford/GM put together a kit that is the differences between an FFV model and a non-FFV model. Fuel lines and injectors aren't that hard to replace, and if you could just reflash the computer and add a sensor, I think a lot of people would make the switch.
Does anyone know how are cars are handling the switchover to 10% ethanol as an additive instead of MTBE? Is it just a low enough concentration that things don't corrode whereas E85 would eat away at natural rubber, alumninum, and magnesium?
-Jim
Old May 25, 2006 | 06:56 AM
wendell borror
That may be , but canada doesn't set market price, opec does who is controled by the arabs !!
Old May 27, 2006 | 05:47 AM
jimw411's Avatar
jimw411
e85 is crap, is doesn't save you any money cause you gas milege goes down about 5 mpg running it. You might as well stick with the th better ecomny of the gas thats $1 a gallon more.
