Manitoba / Saskatchewan Chapter Join Chapter, Leader: Fomoko1
352 update
Old May 23, 2006 | 10:42 AM
Snowking's Avatar
Snowking
352 update
The compression is up. I am not jumpin for joy yet, but breathing a little better.
I still got one piston under fifty but each time it comes up a little.
The motor has enough power to start in secound, and in a test it started in third, I know that's a rough test but it got me a little more confident. I've taken her into the fields and climbed any hill I found. It won't be doing anything amazing in power terms but it has enough for me.
The timing is still a bit late I was going to fix that, but our timing gun went out.
One thing weird every time you start it you must pump twice and pull the choke. Regadless if it hasn't ran for days, or if it ran 4 secounds earlier, any different it won't go. (I've tried by trial & error)
Old May 24, 2006 | 12:41 AM
preppypyro's Avatar
preppypyro
Thats good to hear man, glad its starting to get a little better instead of worse!
Old May 24, 2006 | 12:43 AM
Fomoko1's Avatar
Fomoko1
Looks like you`ll end up with a driver after all.
Old May 24, 2006 | 02:31 PM
Snowking's Avatar
Snowking
Ya, I think one day she'll be back on the roads....or the fields.
Old May 24, 2006 | 02:36 PM
ARMORER's Avatar
ARMORER
Funny. The 352 in my Galaxie is the same way. You have to pump it 5 times, turn the key and it will start then immediately die. You must then pump it once and turn the key. She roars to life, and runs awesome. This is regardless of whether it has just been run or not-same procedure every time.
Old May 24, 2006 | 07:00 PM
Fomoko1's Avatar
Fomoko1
Sweet 64 Galaxie, thanks for dropping ARMORER.
Old May 25, 2006 | 11:39 AM
ARMORER's Avatar
ARMORER
Thanks man, your Mustang is a killer ride! Is that "Indian Fire Red" ?? I like that dark shade.
Old May 25, 2006 | 01:49 PM
Snowking's Avatar
Snowking
I finally got my 352 on the road and in high gears, you can tell it wasn't ran for a decade AT LEAST but it's kind of a gutsy motor still.
Old May 25, 2006 | 02:55 PM
ARMORER's Avatar
ARMORER
Cool. They have amazing low-end power. And they're loud. I really don't mind my 352. When it's time for a rebuild, I may not keep her-just because they are pretty heavy. A 302 or a 351W would move my Galaxie just fine. But in a truck where weight isn't so much an issue-the 352 would stay.
Old May 25, 2006 | 10:39 PM
preppypyro's Avatar
preppypyro
Yeah amazing galaxy armorer, looks like a deadly car!
Old May 26, 2006 | 12:19 AM
Fomoko1's Avatar
Fomoko1
No, it`s the orginal Candy Apple Red this Mustang was born with. My 69 F100, the 71 F350 and the 83 5.0 convertible are all in this, my favorite colour.
Old May 27, 2006 | 10:01 PM
preppypyro's Avatar
preppypyro
All look very nice to fom, I think we need some pictures of your 83 convertible though
Old May 28, 2006 | 11:27 AM
Fomoko1's Avatar
Fomoko1
You can see it the next time you`re intown, more coffee and donuts....
Old May 30, 2006 | 12:40 PM
Snowking's Avatar
Snowking
My International brake master cylinder gave out. I'm thinking but fearing liscencing my 67 with the 352. It still starts rough and the brakes are sketchy. I think I should, I think I can.
Old May 31, 2006 | 06:01 PM
preppypyro's Avatar
preppypyro
For sure fom, I never get to go to saskatoon as often as I like though.
MRSMOGSTACK
42
Feb 11, 2011 12:52 PM
jlo84truck
Apr 1, 2009 10:50 PM
Snowking
Oct 22, 2007 06:05 AM
16diesel
Feb 27, 2006 08:58 PM
jayr
Sep 4, 2002 01:28 AM
