4x4 Hubs???
Old May 23, 2006 | 06:57 AM
dsldandually's Avatar
dsldandually
4x4 Hubs???
Well for some odd reason my left front hub has eaten itself....lots of little pieces cant understand what would cause this since I dont wheel or abuse this truck. I only use 4 wheel once in a while in the winter when the goin gets real bad. Just plain old manual hubs no vacume BS. Anyone have any idea what would cause this??
Old May 23, 2006 | 07:21 AM
PSNut's Avatar
PSNut
Probably these salt brine NE roads. I just replaced a rear U joint at 64K miles. Totally frozen in place and needed to be torched out.
Nut
Old May 23, 2006 | 10:09 AM
Grunt0311's Avatar
Grunt0311
I would say either corrosion, or a bad wheel bearing throwing your spindle out of wack, and tearing up the hub. However, if it was this bad I would think you would be hearing some metal grinding by now!
Bill
Old May 24, 2006 | 12:33 AM
dsldandually
no strange noises wheel bearings are tight. will it hurt anything to just put the gutted hub back on and drive until I can get new ones?
Old May 24, 2006 | 06:04 AM
Kwikkordead's Avatar
Kwikkordead
I have a real aversion to reinstalling broken things back onto things that are still good. I recommend removing whatever might fall off and ruin the bearings. Use the hub cover as a protective cap and have a 2 wheel drive until you get the new hubs in. Or just park it.
Old May 24, 2006 | 06:16 AM
dsldandually
Kwik
That is pretty much what I have done I just took everything out of the 4x4 hub and used the housing as a dust cap until I can get some new ones.
Old May 24, 2006 | 06:17 AM
Kwikkordead
Oh, OK, that's good.
crobotti
Apr 9, 2014 10:35 AM
ZEALOUS_DRAGON
Jan 27, 2011 11:58 AM
af11
Offroad & 4x4
Jan 15, 2011 05:20 AM
mrcool61199
Mar 23, 2010 01:42 PM
73cj5
Mar 19, 2006 06:07 AM
