Truck working hard while towing
Old May 22, 2006 | 05:02 PM
bigkess's Avatar
bigkess
I took the camper trailer out this weekend and my 04' PS seemed to be working REALLY hard. I'm a diesel newby so bear with me. I read on the forum all the time about people going up hill, passing people because of all the towing power these trucks have. It seemed to me that I was really "chugging". My trailer loaded is about 4500 lbs. I am using a Bullydog Power Pup set at about 30% power increase. I have a Prodigy brake controller which is set to "boost 1". We went about 120 miles round trip with 6% uphill grades about 1/2 of that distance. Seemed to take a long time between when I pushed on the gas and when the "power" kicked in. I also noticed a sustained high pitch whine at times. I'm not sure, but I thought mabye it was the turbo spooling up. On this 120 mile trip I used about 1/2 tank of gas. Maybe I am being paranoid as I haven't towed a lot of heavy items anyways. Any thoughts anyone has? Do I have a problem, or is what I am describing "normal" sounding? Thanks!
Old May 22, 2006 | 05:37 PM
cthehentz's Avatar
cthehentz
That does'nt make since, I have an 03'ccPSD FX4 6.0 all stock and pulling my 33' toy hualer with 4 quads that weighs in at 14000 plus lbs and I still get 13mpg, and will pull 65mph up Baker grade going to the duemont dunes in Cal. Have you changed your fuel filters? At one time I had a lack of power and I found that the bottom filter " inner rail " had never been changed when I thought it had. Just a thought.
Old May 22, 2006 | 05:39 PM
Stewey's Avatar
Stewey
Did you just purchase the truck? If it acted the way you say, I definitely think you've got a problem. Was it smokin' going up those grades? When was the last time fuel and air filters were changed? Start there.
Old May 22, 2006 | 05:53 PM
bigkess's Avatar
bigkess
I bought the truck last July. I haven't changed any filters (fuel or air) so I will check those. The air filter "guage" shows still good, but maybe not. No, not smoking going up the hills, just seemed to be going really slow. cthehentz- what you describe is what I would expect. When you hit the gas does it get up and go quickly?
Old May 22, 2006 | 08:27 PM
cthehentz's Avatar
cthehentz
There is a 1-2-3 second delay from the turbo but then it's hold on and she goes. Changing the fuel filters is the first step and that's both, one on top of the motor and one on the inner frame rail below the drivers seat, I would also pull the air filter and look at it to see if it looks dirty or just replace it for peace of mind.
Old May 22, 2006 | 11:55 PM
bigkess's Avatar
bigkess
Thanks. Is the sustained "turbo whine" anything to worry about or is that normal? I just don't remember it doing that last year when I was pulling the camper.
Old May 23, 2006 | 09:30 AM
Fasttrax's Avatar
Fasttrax
The whine may be your fan kicking in. Mine starts to whine at 220 degrees andf on hills. Its a variable whine. Hard to get used to cause my stock 01" 7.3 didn't do that.
Old May 23, 2006 | 10:00 AM
X GM GUY's Avatar
X GM GUY
04, 2wd, CC, Lariat,6.0L, 6 sp. This is what I've noticed since the last flash. (Nov 05), more turbo whine. The truck seems to lack power untill its pulled about 15 miles. There only seems to be about 1-2 mpg difference between towing my 5th wheel,18,000 lbs and my race trailer 13,400. The truck will get 20- 22 mpg empty, with the 5th 10.5 mpg and with the race trailer 11.5 to 12.5.
Old May 23, 2006 | 10:04 AM
Fasttrax's Avatar
Fasttrax
Have it reflashed again. Mine did the same. Dealer mentioned the recall flash was inproperly done and reflashed it again. Back to normal now. See the thread on the reflash in here.
Old May 23, 2006 | 05:37 PM
bigkess's Avatar
bigkess
Thanks. I will check with the dealer on the reflash. I hate seeing those posts where guys are getting 20-22 mpg :-). I average about 14 around town. Dealer told me the leveleling kit and tires will kill mpg...
Old May 23, 2006 | 10:46 PM
cthehentz's Avatar
cthehentz
You know I took mine in for a recall/reflash and they changed the egr and vgt? They did a full checkup on the truck and replaced these parts and some others all under warranty. I did notice a small lack of power but it could be me. The best mpg I can get is 18 and that's NO Hot DOGGIN, I'm 36 and I have to drive like I'm 76. The only people I know of getting 22mpg have a chip and pakage of goodies added. My truck is bone stock and that's the best mpg I can get, 13 towing and 18 staying off the gas.
Old May 23, 2006 | 11:24 PM
bigkess's Avatar
bigkess
That's what drives me crazy! I HAVE a chip and I drive like an old grandpa too :-). Still get crap mileage!
Old May 24, 2006 | 11:58 AM
bigredtruckmi's Avatar
bigredtruckmi
Veteran: Navy
Did I see you have large tires on the truck?? If so this will hurt MPG. My 04 on 6% grades pulls 10 K without coming off overdrive. I have squalked the tries with the trailer on. I just tell my wife to hold on while we merge on the freeway. Everything on my truck is stock. I get 20MPG on freeway and 12-14 towing thru mountains
Old May 24, 2006 | 05:07 PM
bigkess's Avatar
bigkess
They don't seem huge to me, but I don't know what size the factory tires are. I am running BF Goodrich All Terrain T/A tires, size 315/70R17. I think that translates to 33X12 tires. I have those tires on, a 4" leveling (not lift) kit, and the Bullydog Powerpup programmer running (set at 30%). Other than that my truck is stock. In your opinion (or anyones out there) would that make that significant of a mpg difference? Thanks.
Old May 24, 2006 | 07:05 PM
bigredtruckmi
Veteran: Navy
Not sure on how they compare but mine from the factory on our 04 is B F Goodrich Lt 265/75R16 Rugged Trail /TA load range "E" Look at my signature to see what I have for equip on our 04.
Check your door sticker to see what was on originally.
Maybe someone who knows tires will be able to help....
