Truck working hard while towing
Old May 24, 2006 | 08:21 PM
bigredtruckmi's Avatar
bigredtruckmi
Veteran: Navy
Found this tire size calculator. For a stock tire using my tire as stock and yours as new. Stock turns 637 times per mile and the new is 587 times per mile. Speedometer reading will be 8.6% slow or with new tire your speedometer will read 60 but the law if he is around will say your doing 65.1 MPH
So with these calculations I would be pretty sure it will take a lot more HP to go down the road especially when towing. Then the fuel mileage would go down.
http://www.miata.net/garage/tirecalc.html
Old May 25, 2006 | 08:54 AM
Fasttrax's Avatar
Fasttrax
On both of my powerstrokes i've owned I have never been higher than about 11.5 mpg towing my toy hauler. Empty the best has been about eighteen with downhill grade and lower elevation. It would be interesting to know what elevation the 18+ mpg guys are running. I have had 35's on both trucks.
Old May 25, 2006 | 10:49 PM
bigkess's Avatar
bigkess
Thanks bigredtruckmi! Any math wizards out there that could do the exact calculation? Good point Fasttrax. I hadn't thought about elevation. I live at 4400 ft above sea level and when I tow, it is up to between 6500 and 10000 feet above sea level. Any higher eleveation folks getting the 18-22 mpg?
Old May 26, 2006 | 08:19 AM
kw5413's Avatar
kw5413
Try this as well.
http://www.csgnetwork.com/speedocalibcalc.html
Old May 26, 2006 | 10:08 AM
Hunter40's Avatar
Hunter40
I live at 8,000 ft and frequently drive to Colorado, anywhere from 6,000 to 11,000. My last two trips have seen 21 mpg highway from NM to Colorado Springs and back via LaVeta pass.
glsurratt
16
May 22, 2015 04:08 PM
zgraham
Sep 3, 2013 10:09 PM
darknightjedi
All Things Towing
17
Feb 23, 2011 06:43 PM
Jettix2
All Things Towing
37
Feb 16, 2009 08:08 PM
Twin Tritons
May 17, 2004 11:08 AM
