Engine will not start
Old May 22, 2006 | 03:04 PM
ggirten's Avatar
ggirten
I have a 99' F250 7.3. The engine will turn over, but it will not start. The wait light is not coming on. Anyone run into this problem? I had one guy tell me he thought it was the fuel heater.
Old May 22, 2006 | 03:57 PM
arninetyes's Avatar
arninetyes
Is it stock? Do you have a chip?
Old May 22, 2006 | 04:05 PM
ggirten's Avatar
ggirten
Yes, it is all stock.
Old May 22, 2006 | 05:46 PM
Mr Huckle's Avatar
Mr Huckle
Smile
ggirten
I had the same problem. It turns out that the 7.3 has same recurring problem (Camshaft Sensor). They typically should go around 120 K but mine lasted to 147K.
The part is about 170.00 from ford or about 300.00 installed by a reputable mechanic.
Good Luck
Old May 22, 2006 | 05:57 PM
PSNut's Avatar
PSNut
Originally Posted by Mr Huckle
ggirten
Good Luck
U can get one from the IHC dealer for $100 or online for $100. About 20minutes to install with 10mm deep socket.
Nut
Old May 22, 2006 | 07:02 PM
Kwikkordead's Avatar
Kwikkordead
Hold on guys.....
No wait to start light is most likely a shorted fuel heater. Check the fuses under the hood, if one of them is blown, disconnect the plug on the back of the fuel filter housing, and try another fuse.
Old May 22, 2006 | 08:58 PM
ryaneverk2's Avatar
ryaneverk2
Originally Posted by Kwikkordead
Hold on guys.....
I was just about to hit REPLY and post this when I scroll one post further and see Dan's post.
No WTS light means the PCM isn't getting power... and the fuel heater shorting blows fuse #30, which is also protecting the PCM. Sooo.... check fuse #30... it's a 30amp, and I'll betcha it's blown. I hope I'm remembering the number right... check all the fuses just in case.
Old May 22, 2006 | 09:59 PM
Kwikkordead
If it was a blown fuse, it wouldn't start at all. It's worth checking the fuses anyway, but where's this delay coming from?
EDIT: OOPS!!! wrong thread for this reply. Please ignore.
Old May 23, 2006 | 07:36 AM
ggirten's Avatar
ggirten
All fuses checked OK. I had a guy check it with a scanner. He said it looked like the fuel heater has shorted out. I am going to have to go through the wiring to see if any are bare.
Old May 23, 2006 | 06:31 PM
ryaneverk2's Avatar
ryaneverk2
If the fuel heater shorted, it would blow fuse #30 IIRC, which I believe is under the panel under the dash, so check those if you haven't yet. Did you check those fuses or just the ones under the hood? It's a 30 amp fuse.... protects the fuel heater, PCM (which causes the no-start and no WTS light), and a few other things.
Old May 24, 2006 | 07:39 AM
ggirten's Avatar
ggirten
I have checked quite a few fuses, but I can't be certain about that one. I will check it after I get home from work.
